25-30hz tapped horn recommendation please... TB w8-740??
Old 30th June 2010, 02:29 AM   #11
djk is offline djk
djk's Avatar
They are to illustrate the general form a TH can take.
The 30hz TB horn on his site is different than the Hornresp design I presented, different driver, different box design, similar results.
Candidates for the Darwin Award should not read this author.
Old 1st July 2010, 02:41 AM   #12
david45 is offline david45  Canada
Thanks DJK
btw I posted the same thread on the AVS forum and I've been getting quite a few suggestions... it's not making things easy
Old 1st July 2010, 03:51 AM   #13
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I have merged your two accounts into david45 so Bear's question now seems out of place. Dual accounts are not permitted here.
planet10 needs your help:
Let's help Ruth and Dave
Old 1st July 2010, 04:05 AM   #14
sorry about that Cal let's just blame it on the fact that I'm really not used to posting on forums.. i usually just read treads...
dave
Old 5th July 2010, 04:06 PM   #15
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
Bjorno, I'm really curious about that T-TQWP. But, those thumbnails are a little small for me to see what is going on. Could you post bigger images?
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 5th July 2010, 06:42 PM   #16
GM is offline GM  United States
GM's Avatar
When you click on it, there should be a four arrow image down in the LH corner to click on to make it full size. In Firefox, I usually just right click on the small image and open in a new tab to get the full size.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th July 2010, 08:22 PM   #17
pjanda1's Avatar
Duh. Sorry about that. I'm still trying to decide what to do with my pair of W8-740Cs. I know the TH-SPUD clone is the safest option, but I'm just not crazy about the shape and volume. I'm looking for something (or somethings) that takes up less floor space.
Paul
Old 8th July 2010, 01:27 AM   #18
dwk123 is offline dwk123
I found the T-TQWP design interesting when I first saw it as well - thanks for bumping the thread since I had forgotten about it.
bjorno (or anyone else with experience with these) is this really a practical design? the cross-section is basically a square tube 3.5 inches per side - is this viable with a fairly beefy 8" driver? I'm not even sure how you'd construct such a thing, and would think at the very least that a front chamber/rear chamber might have to be modeled.
Also, would a T-TQWP be stuffed, or just lined like a conventional TH?
Is it a coincidence that the F3 is very close to Fs for the driver? Most TH designs are ~0.5 octaves down from Fs.
Definitely a very interesting design if it can be made to work.
Old 4th August 2014, 09:19 PM   #19
sabaspeed521 is offline sabaspeed521  United States
Default More design ideas, 114 dB free space max output to 31
Here is a 10 inch driven 250 watt design that I've been modifying (adjusted from a 40 Hz TH pipe to a 31 Hz one) that should do 114-115 from 31-90 +-2 dB with no added inductors. The driver is 50 bucks free shipping see Alpine Type-E Subwoofer SWE-10S4*| Creative Car Audio
see this forum thread for the original design (I am basically stretching it wider and taller to make the hornresp numbers correct). Should be roughly 3.5 cu. ft standing on end with a foot print of roughly 14x14inches. http://www.diyaudio.com/forums/subwo...h-order-3.html
Old 8th August 2014, 10:30 AM   #20
Bjohannesen is offline Bjohannesen  Denmark
my "invisble" sub might inspire you. Now I use the SCANSPEAK 10" and Hypex 1.2 amp. The perfromance is impressive, as it is looks rather small.
Hi
Bjørn
File Type: pdf Hide Away SCANSPEAKSCANSPEAK 4558T00.pdf (760.1 KB, 133 views)
http://www.kvart-bolge.com/
25-30hz tapped horn recommendation please... TB w8-740??Hide this!Advertise here!
30hz 10" tapped horn magic? killerfishes Subwoofers 10 27th December 2009 06:53 AM
Subwoofer with Tangband W8-740 norrback Subwoofers 10 15th October 2007 09:06 PM
suitable horndesign for TangBand W8-740 Mayday Subwoofers 10 15th April 2007 04:12 PM
W8-740 in sealed sub? toseland Subwoofers 2 1st December 2004 08:48 AM
Copyright ©1999-2017 diyAudio
