First the mystery:
I'm using two 12" DVC drivers in a sealed enclosure as my car audio subwoofer. The driver's parameters (measured with a WT3) are approx Fs:18.8 Hz, Qts:.457, Vas 3.767, Re: 1 Ohms (coils in parallel). The box is approximately 2.8 cu.ft., and stuffed. The coils for each driver are set in parallel, and the drivers are wired in series. This should result in a system with an Fb around 32~36 Hz, and Qtc around 0.74~0.83, and impedance should be 2 ohms. However... ...the WT3 is saying that the Fb is 33 Hz and the Qtc is 0.96(!). I thought additional series impedance may be contributing to the problem. I checked and it came up to 0.2 ohms. I ran new cabling and redid the connections, and managed to bring this down to 0.08 ohms. Qtc dropped a bit, but it's still quite a bit higher than I expected. The box itself is not one of best pieces of work - looks ok, but a little too much vibration for my liking. Still, why the higher than expected Qtc? Now the choice... I want to upgrade the subwoofer. Fb is a bit too low for car audio use, and the overall efficiency is a bit too low for my liking (I'm using a class D amp that can feed the drivers 250W each). I'm therefore looking to replace the drivers and rebuild the box. Two drivers have caught my attention: the $139 Trio12 (http://www.creativesound.ca/pdf/CSS-...ata-051009.pdf) and the $125 SSA DCON (Sound Solutions Audio - DCON Series Subwoofers). The Trio12 looks like a pretty decent driver and looks like it might work well as a car audio sub in a small sealed box. Efficiency at 85dB/1W/1M isn't a whole lot greater than my current drivers however. The DCON12 is a lot more sensitive (89dB/1W/1M), and it's lower Q (0.33 vs. 0.43) suggests that I can actually use a small vented box instead if I want even more output, without having to worry about a significant hump in the passband. It also has dual spiders and it's cheaper than the Trio12. However, it doesn't have an XBL^2 motor and its rated Xmax is just a little lower (16mm vs 20mm). Tough choice and I can't seem to make up my mind. Any suggestions? |
#2 |
Yes the higher Qtc is a mystery... just for fun It would be interesting to wire the DVC in series first remeasure and then wire the drivers in parallel and recheck Qtc. I think your idea to wire the drivers in series is good BUT the individual driver coils in parallel Re ~1ohm is too low for the WT3 to measure accurately as this is the area of 4 wire measurements now.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#3 | |
#4 |
Try removing the stuffing and check again. You might be choking off the airspace.
#5 |
Qtc value changes due to stuffing are suspect below 50hz.
When the waves are slower, there is less friction to cause the loss of energy to mimic a lower Qtc.
Candidates for the Darwin Award should not read this author. |
#6 |
#7 | |
It's all very strange. I think I'm going to try to take all of the stuffing out, to see what the unstuffed box measures like. |
| Mystery Speakers??? | mikje | Multi-Way | 3 | 24th October 2009 07:16 AM |
| little 6.5 mystery ... | oface | Full Range | 6 | 4th November 2007 11:20 PM |
| mystery regulator? | hihopes | Solid State | 0 | 22nd July 2007 09:39 PM |
| Mystery parts 2 | bdeko | Parts | 3 | 24th February 2007 03:51 AM |
| mystery... | mista2 | Multi-Way | 1 | 14th January 2005 04:20 AM |
| Page generated in 0.09474 seconds (78.74% PHP - 21.26% MySQL) with 10 queries |
