Old 24th June 2010, 10:53 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default What do I need to filter bass to a sub?
Basically just building my sub and have got a single channel amp which is the complete frequency range but i only want 500Hz and below what do I need to do this for a 4ohm speaker? Can I use a crossover calculator and then use a crossover without the tweet or mid-rand outputs?
Boscoe
Old 24th June 2010, 11:06 PM   #2
Okay so I just found the butterworth 3rd order low pass and it says to use a cap with a certain polarity (late i can't think of the name!) so can I just use electrolytic caps or is ther e a certain type needed?
Old 25th June 2010, 01:51 AM   #3
tinitus is offline tinitus  Europe
then its basicly considered as a common 3way
Old 25th June 2010, 07:25 AM   #4
chris661's Avatar
Does seem very high for a subwoofer. What are you crossing it over to? (some bookshelf speakers, other drivers in that cabinet...?)
Which driver are you using - you need the impedance curve so you can select the impedance for the frequency you want.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 25th June 2010, 08:50 AM   #5
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
500 Hz is just below middle C on a piano.
That is a high note for a sub.
Go get a feel for frequencies, listen to some test tones!
Old 25th June 2010, 09:42 AM   #6
Okay the driver is one I have just lying around and I'm going to change the frequency to 200Hz.
This is what I'm going to use (in the highlighted area)
I am using two 8ohm drivers with both inphase for a sub woofer.
Old 25th June 2010, 10:26 AM   #7
3pole filter and 200Hz will pass a lot of mid range to the bass only drivers.
Turning off the satellites, you will clearly recognise the low passed music & songs with all that mid range content.
The filter components will almost certainly be unavailable in 1% values.
5% values are getting a bit wide for a 3pole filter. The tolerance must be tighter for higher pole filters.
4m7H or [4m7H + 100uH] for 4.77
270uF or [220uF+47uF] for 265
1m5H or 1m6H or [1m5+75uH] for 1.59
You may need to add a Zobel correction across the driver terminals to bring the driver load closer to the assumed 8ohms that your calculator uses.
Personally, I would add an active filter in front of the power amp and drive each 8ohm speaker with one half of a stereo amplifier. The active filter could be a CFP which inverts the signal and also capable of summing two (or many) channels to a mono channel.
regards Andrew T.
Old 25th June 2010, 01:38 PM   #8
Xoc1's Avatar
If you use an active filter and a separate amplifier you are far more likely to get a satifactory result.
Also if you are not happy with the frequency response, you will be able to modify it with a few pence worth of components.
At the moment if you build this passive filter, and your not happy with the result (which is very likely) you will end up with a expensive load of junk!
Old 26th July 2010, 01:39 PM   #9
Paradigm x30 sells used for under $100.
Infiniti makes a similar device.
Or get a 2/3 way stereo active crossover from Behringer for $99.00usd. Being adjustable is a major plus with any project. I have just ordered a CX3400. Or get a costlier digital unit such as the dcx2496 for $299.00
BTW A subwoofer will want a frequency cut-off at 50 or 80Hz. Not 200Hz.
bass filter mlkirchgessner Car Audio 3 1st March 2007 02:52 PM
Bass beat filter malc c Everything Else 9 2nd January 2007 09:57 AM
Active filter for bass dipole felixx Multi-Way 1 7th December 2006 12:05 PM
Help Creating Bass boost filter. PaulHilgeman Analogue Source 2 28th February 2003 09:44 AM
subwoofer bass extension active filter? capslock Subwoofers 8 12th September 2002 05:05 PM
Page generated in 0.10714 seconds (74.04% PHP - 25.96% MySQL) with 11 queries
