Location: Where the world's best tea come from:Kericho Kenya
Hi guys,
I am debating wheather to purchase this sub.The specs are quite tempting for a midium power sub.Has anyone ever used this before?How accurate are the specs? Claimed specs: rms 250 watts (max.1200 W) sensitivity 95 db frequency response 20-180hz. Regards
if there are no sparks,it probably doesn't work! |
#2 |
Hi, I actually just put a TS-W3004SPL into my sub box just to get an idea of what it would sound like as I am about to build a new box for it.
The box it is in is too small for it but even so it sounds really really good, it dops very low, so I can say it will sound even better when its in the new box. Here is the manual that its shipped with, maybe it will help you decide. http://www.pioneerelectronics.com/St...Manual0522.pdf And this is the one that I am using,(if you want to make a comparison) I actually have two of these. http://www.pioneerelectronics.com/pi...D1263-A_UC.pdf I hope this is of some help to you. |
#3 |
FYI: the published specs are ambiguous at best since its Mms, Cms, Rms, BL calculates considerably different Fs, Qts, specs to the point where the latter dictates a near doubling of cab net Vb, so short of measuring them, using a sealed alignment based on its Fs, Vas, Qts seems a reasonable choice; but at ~16.8 ft^3 seems a bit much considering its Xmax severely limits its low distortion peak SPL down low if there's not a significant amount of room gain like one gets in a typical vehicle.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 | |
b |
| To sell: one Polk 12" "metallized" subwoofer | kencogan | Swap Meet | 0 | 16th January 2010 02:21 PM |
| 12"Pioneer 400W subwoofer with a RF Punch 360.2 amp? | bigwig | Car Audio | 1 | 11th January 2005 05:42 PM |
| 12" 2ohm round Solobaric TS Parameters | dok33 | Car Audio | 1 | 15th May 2004 09:00 PM |
| Pioneer TS-W34C 12'' sub for a dipole | static | Multi-Way | 6 | 1st January 2004 09:34 AM |
| I need T/S parameters for Pioneer TS-W305DVC subwoofer | Stephen D | Car Audio | 2 | 11th December 2003 08:35 AM |
| Page generated in 0.06472 seconds (83.63% PHP - 16.37% MySQL) with 11 queries |
