#51 |
First, I'm thinking that a front mouth might be a little more flexible for positioning experimentation allowing the cabinet to be closer to the front wall ''if necessary'' cause it's of course not my preferred location.
Secondly, Last night I did a bunch of simulation with different drivers(in WinISD) and the Trio12 looks excellent, quite versatile and great value versus drivers like Dayton RSS and Titanic and several Eminence drivers for exemple. So, so far, I'm leaning towards the Trio12 to be my driver of choice...( impressive lower extension in a vented 115L box tuned to 21Hz) but... I'm a little unsure about the enclosure. The Shadow enclosure seams a little different in design from the Replikon so I do not have much to refer to to figure out how the Shadow enclosure will perform... Lower frequencies extension? Dynamics? Accuracy? And even though I am confident in it's doability, it's not the simplest enclosure for so little info on how it will sound... and lets not forget that I want to build a couple of them. Any opinion/suggestion to help me ? PJeff |
#52 | |
#53 |
frugal-phile(tm)
You get even more versatility by doing mirror pairs of the 1st one with side firing mouths.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#54 |
#55 | |
So, let's start with the basics... do you think the Trio12 is a good value driver choice for what I want to do in it's price range(139$)? (Reckhorn F-1 stereo to a 100w/8ohm integrated amp driving a couple subs, seeking clear, good transient sound to complement stereo monitors, lower extension 30Hz flat, at least 95dB, for music+movies) PJeff Last edited by PJeff; 9th July 2010 at 07:38 PM. |
#56 |
frugal-phile(tm)
yes, yes, yes... go for it.
dave
#57 |
Hi PJeff,
This may be as good a project as any for getting into Hornresp :-). Here is one way this can be simulated in Hornresp. Basically as a back-loaded horn with a large throat chamber, a short coupling section to the straight duct, and a second coupler to the port horn. After hitting calculate you must use the combined response button to see the in-room total, the path length is probably in the neighbourhood of about minus 45cm. You can also use the sliders in the Horn Loudspeaker Wizard to modify the individual dimensions. Regards,
Oliver |
#58 |
#59 | |
I've played around with that and what i've noticed, with my limited knowledge, is that the extension is somewhat limited in the Shadow enclosure compared to something like a ported 119L box tuned to 20.6Hz(see attachments). Do you see any advantage the Shadow has in other areas? Dave any thoughts? I need help here!!!! ![]() How can I get the cleanest reproduction and best transient with a decent lower extension with a stereo installation(two seperate enclosures) with the Trio12(flat to 30Hz in room if possible) without much calibration other than placement? PJeff |
#60 | |
| 300B stereo amp project help | bartasas | Tubes / Valves | 2 | 27th March 2009 03:27 AM |
| Novice Question: Stereo Woofers in One Box | joshkrahn | Multi-Way | 7 | 20th December 2007 01:31 PM |
| My stereo bike project HELP!! amp problems.. | the bass master | Car Audio | 0 | 7th February 2004 04:33 PM |
| Completed stereo amp project | Solid Snake | Solid State | 3 | 26th January 2004 05:20 AM |
| DIY Stereo Subs | Super | Subwoofers | 46 | 8th October 2001 05:03 PM |
| Page generated in 0.12603 seconds (84.59% PHP - 15.41% MySQL) with 11 queries |
