Old 15th June 2010, 05:34 PM   #1
ro9397 is offline ro9397  United States
Default Clearance: down-firing port to spikes?
On my sub enclosures the down-firing port base is flush with the enclosure, not recessed. What is minimum safe clearance from the port/enclosure base to the tip of spikes for thick carpet and pad?
10" driver faces the wall with about 3/4" clearance. If I compute correctly, and if it makes a difference, in effect the port is open about 180-degrees and closed off on the wall side.
1.1cf internal, 10" super duty 16 lb net weight, 600Wrms power handling, port about 2" x 16" moving (apparently) a lot of air, 20 Hz clean in current state of tune (four employed total, one in reverse polarity).
TIA!
Jimbo
"Television is the poor man's whiskey." Russel Baker
Old 15th June 2010, 06:56 PM   #2
infinia is offline infinia  United States
infinia's Avatar
Port air velocity with 2"x16" port?
I've read where one port radius is all the clearance that is required. But your port area seems to be too small for such low tuning> unless low SPLs due to Xmax limitations. Can you show us your box calculations/tuning to acheive 20Hz? What power is Xmax reached?
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 15th June 2010, 07:10 PM   #3
badman is offline badman  United States
Custom Title
badman's Avatar
You want to have a significant increase in area so as to have the gap between box and floor not act as a vent extension. I'd go 3" in your case.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 15th June 2010, 10:58 PM   #4
Sorry, a real speaker designer licensed me to build this. I double checked, and he specified to allow "60ci" for port displacement in the box, and it looks like it's closer to 2" x 20" in length. It's also tuned for reverse room gain, meaning 3 dB/octave roll off below 100 Hz. So I suppose its about -7 dB @ 20 Hz relative to 100 Hz (or -10 dB @ 20 Hz if that's the -3 dB point, which may well be the case). Xmax: 12.3mm
I must admit I'm surprised how variable are the replies.
Jimbo
Old 15th June 2010, 11:37 PM   #5
infinia's Avatar
Well... speaker design is not an exact science. But maybe a real designer would disagree with that. LOL
If you have supersonic port velocity I would allow much more distance to the floor ...FWIW If'n I was was you I would get a second opinion about that port.
Old 16th June 2010, 08:16 AM   #6
chris661's Avatar
I'd agree - that's a very small port, especially for the amount of excursion on offer.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 17th January 2011, 07:33 AM   #7
How did Tannoy manage with Subwoofer of HTS-100 system? I am posting its pic. This system sounds very impressive at its cost.
I heard them lot of times at Cafe Coffee Day. Coffee tastes good with this.
There is always a first time....
Front firing vs down firing sub? alex_g Subwoofers 32 22nd June 2010 12:34 PM
Port firing downwards? markusA Full Range 14 29th April 2010 05:19 PM
what is the impact of having a rear firing port peteS Multi-Way 8 4th March 2006 03:43 AM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
position and clearance of port in a MLQWT design Puggie Multi-Way 5 11th February 2005 05:47 PM
Page generated in 0.08788 seconds (77.33% PHP - 22.67% MySQL) with 11 queries
