I've had a pair of Adire Koda 8 sitting on the shelf for over two years begging to be used . A tapped horn looks like a good application as these have X-max of 12mm . Two Hornresp alignments are shown but I'm at a loss which one to go for . I'm not after mega SPL's but wondering what the drawbacks are for each set of numbers . I can see the magnet of the Koda may be an issue , would it be advisable to 'build out the horn around the magnet ?
cheers 316a |
#2 |
Interesting, based on sims, until tuned very low, this driver doesn't seem to like to be horn loaded at all. Anyway, in theory, the sim's peaking will be flattened somewhat, so if such a narrow BW works for you, then either should be fine and since more efficiency is always theoretically better, the larger of the two would be my choice.
That said, from just looking at some pictures, this driver's surround doesn't look like it can handle any real acoustic compression, so if this driver wasn't recommended for BP loading it probably won't do well in a TH either. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
Thanks for your input . I'm beginning to think the Ciare 12SW may be worth investing in rather than using the currently 'free' Koda 8's
cheers 316a |
#4 |
You're welcome! Not familiar with the Ciare, but the Koda seems best suited for a small sealed cab.
GM
#5 |
I would just go for a normal bass reflex box. You'll need the extra efficiency at the bottom end, else you'll have to add equalisation. I'm assuming that your application is home use, not in a car...? Else, if it is for car use, I'd agree with previous poster and use it sealed.
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#6 | |
#7 |
Yeah, I looked at a low tuned vented alignment, but the vent is so long it might as well be a TQWT or a tapped variant, though again, I'm kind of skeptical about the latter with this driver, but only one way to know for sure though.
GM
#8 | |
GM
| Gamma Horn loaded Ribbon VLD-13 - Application Advice Needed | icefox | Multi-Way | 30 | 9th June 2010 09:22 PM |
| Can a Tapped Horn have a negative taper within the horn path? | BP1Fanatic | Subwoofers | 6 | 13th February 2010 06:04 AM |
| Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background | layertone | Subwoofers | 15 | 23rd January 2010 05:12 AM |
| Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background | layertone | Full Range | 2 | 23rd December 2009 12:51 AM |
| Help with a tapped horn. | mike james 533 | Subwoofers | 32 | 11th November 2009 02:34 AM |
| Page generated in 0.09719 seconds (78.13% PHP - 21.87% MySQL) with 11 queries |
