U-frame line array subs with BMS's woofers
Old 13th June 2010, 04:57 PM   #1
Legis is offline Legis  Finland
Legis's Avatar
Default U-frame line array subs with BMS's woofers
I'm planning to build a u-frame line array subs consisting of 4x 18 inch woofers per side.
I have been looking at BMS's woofers:
18N860: http://bmsspeakers.com/fileadmin/bms...2010-03-18.pdf
18S430v2: http://bmsspeakers.com/fileadmin/bms...0v2_t_data.pdf
Woofers are advertised to have a low distortion, and from the pictures their motor seems to be vented properly which could indicate that the motor has a low operation noise.
Does anybody have some experience with these woofers?
Old 14th June 2010, 09:26 AM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
Nope, though for dipole use, many favour high Qts drivers (around 1, maybe a little higher).
Perhaps it'd be worth searching for something that fits the bill better.
My work: www.grimshawaudio.com
Old 14th June 2010, 09:47 AM   #3
Legis's Avatar
I intend to use a DCX2496 to equalize the room response (= mainly boost low freqs), high q-value is therefore useless, and it's only an indicator for a sloppy motor system with weak magnet.
I will also continue my project at some point and will monopolize or make a cardioid out of some of those woofers, this kind of planned versatility also calls for "universal woofer".
By the way, the frames are ready:
My current apartment does not allow me to move the frames further from the front wall. Therefore I have to set the crossovers low and/or boost the lowest freqs quite a bit.
U-frame line array subs with BMS's woofersHide this!Advertise here!
H frame vs W frame dipole woofers rick57 Multi-Way 18 8th October 2011 05:58 PM
Best offer on 18 Bravox 5.5" woofers for your line array sqlkev Swap Meet 7 13th September 2006 09:52 PM
Dipole Woofer Array in Multiple W Frame? MartinQ Multi-Way 9 3rd August 2004 10:20 PM
Help with line source array subs!?!?! Turboegt Multi-Way 12 29th December 2003 05:02 AM
t-line subs for a DIY line array tom1356 Multi-Way 17 28th December 2002 01:15 AM
Copyright ©1999-2017 diyAudio
