Old 11th June 2010, 07:02 PM   #1
Default T/S Spec Site?
Do you fellas know of any sites that have a list of different drivers T/S specs?
I need them for a rockford fosgate rfr3110
Old 11th June 2010, 07:27 PM   #2
Driver database
Unfortunately it looks like you have to measure it yourself.
Unless you can dig it up by searching a lot.
*edit* have you tried contacting them?
Old 11th June 2010, 08:01 PM   #3
GM is offline GM  United States
GM's Avatar
Not that I trust them, but better than nothing I guess:
http://www.rockfordfosgate.com/scrip...YWdlPTE*&p_li=
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th June 2010, 01:28 AM   #4
Answer
GM
Thanks for that GM! I found another one in pdf form but it only had the qts and the vas.
Old 12th June 2010, 03:29 AM   #5
GM's Avatar
You're welcome! Let us know how the project turns out.
GM
Old 12th June 2010, 07:18 AM   #6
Thanks, I will! Trying to bridge the gap between my 6th order bp with this little terror.
I have it in a ported sonotube right now. It sounds very good and strong on low power but the port velocity is a little too noisy when cranked up. I might due another ported or bp with it, not sure yet. I'll post some pics when I get around to it.
Out of spec T/s Parameters oublie Multi-Way 19 15th October 2009 09:36 PM
transformer spec skipper Tubes / Valves 3 29th January 2008 10:11 PM
Help with a transformer spec please? Pbassred Solid State 1 18th June 2007 12:38 PM
Sub technical spec. globalweb Subwoofers 11 28th October 2006 06:49 AM
Looking for ETON spec...... coffin Multi-Way 2 21st February 2003 09:58 AM
Page generated in 0.10164 seconds (77.86% PHP - 22.14% MySQL) with 10 queries
