Old 8th June 2010, 09:59 AM   #1
Default What style enclosure did I just build?
Hello all,
Here's my question, what style of enclosure is this? Could it be considered a 4th order bp, ported or sealed? Keep in mind I consider the vehicle to be the enclosure aswell.
This is located in the trunk. "port" fires into cab through backseat area.
Here's a model of the enclosure I'm just finishing up on...
Old 8th June 2010, 12:35 PM   #2
4th order band pass-in-a-car.
Regards Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 9th June 2010, 07:24 AM   #3
Anyone care to run some models for me? I have driver and enclosure specs. I just want to see if what I got is the same. Thanks.
Old 9th June 2010, 10:30 AM   #4
chris661's Avatar
Give us the specs, I expect one of us will have some spare time to run the sims.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 11th June 2010, 11:05 AM   #5
Here they are...
Do these numbers look right to you guys?
They can't even tell you the exact cutout diameter(16.5" is too small)
Old 11th June 2010, 11:52 AM   #6
Here's the specs I have been using to model with...(I tried to save the above((posted)) specs and kept getting errors.)
The voice coils are dual 1 ohm. These speakers can handle 2500-3000 watts peak(even though the manufacturer says different)
The box specs are(for two drivers hence the x 2)...
4.23ft3 sealed x 2 (19.25x19.25x19.75) this does not take into account driver & bracing volume)
.857ft3 ported x 2 (this is essentially all port 19.25x19.25x4)
Old 11th June 2010, 12:40 PM   #7
Edit to above post^^ ported volume is 1.83ft3 x 2 (19.25 x 41.25 x 4)
Try to build an old style DAC, PCM1702 bbp Digital Line Level 16 27th November 2009 08:15 PM
Buffet style china cabinet hutch enclosure. 901Fixer Multi-Way 134 12th August 2009 03:26 PM
New high end style enclosure from Hexateq richardkrol Vendor's Bazaar 5 29th April 2009 12:18 PM
My first DIY build vacuum tube style Gainclone. pinoy82 Chip Amps 6 29th June 2007 07:43 AM
I want to build this sub enclosure HV-MAN Multi-Way 4 4th July 2004 09:37 PM
Page generated in 0.08956 seconds (74.46% PHP - 25.54% MySQL) with 10 queries
