Mivoc subwoofers- low bass, great value; whats the catch? Mivoc subwoofers- low bass, great value; whats the catch? - diyAudio
Old 6th June 2010, 04:47 PM   #1
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Default Mivoc subwoofers- low bass, great value; whats the catch?
http://www.mivoc.com/mivoc/PDF/AW200...nblatt_WEB.pdf
8" driver
fs 30 HZ
rms 120w peak 300w
4 ohm
35 euros....
speaker trade - mivoc - Einzelchassis - AW 3000
12"
fs 27 HZ
rms 180w peak450 w
4 ohm
49.00 euros.
Anyone used these? Can't understand all the spec as its in german but its mentioning passive radiators and BRs- wondering if it could be used in a sealed enclosure?
Old 6th June 2010, 05:16 PM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
Put them in winISD, play around with different cabinets.
My work: www.grimshawaudio.com
Old 6th June 2010, 05:40 PM   #3
Used this LinearTeam
when I input the given specs for the 8" its giving me an 8 litre optimum box for a sealed... is that correct? Seems v small
Old 6th June 2010, 06:24 PM   #4
GM is offline GM  United States
GM's Avatar
Tiny Vas, strong motor = small cab tuned high. Trade efficiency for increased cab Vb/lower F3 by adding series resistance to 'weaken' its effective motor.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 6th June 2010, 06:33 PM   #5
GM
8 litres... thats what I'm looking for, good performance from small sealed box
...except that this unit works much better in a BR!
Old 6th June 2010, 08:04 PM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Bill poster View Post
Anyone used these?
I am actually now building a classic 3way monitor using the 12" AW3000
I decided on a closed box around 40-45 liter netto
Whether its a sub driver or just a nice woofer would be a matter of priorities
I think of it as a woofer
49EUR is a very nice price
sometimes we know very little, and sometimes we know too much
Old 6th June 2010, 08:32 PM   #7
mjf is offline mjf  Austria
hello.
mivoc is a wellknown trademark in germany (see speakertrade/solingen).
there are two german speaker builder magazine's (klang&ton ,and hobby hifi) that worked out examples with this.............
k&t 6/2006 an active subwoofer called versacube (aw300 in 35 liter closed) with a hypex ampmodul....................
k&t 4/2006 a passive bandpass box (two aw3000 speakers front to front built in one vented box...........translation?)
and hobby hifi 5/06 and 6/06...........
greetings
Old 6th June 2010, 08:41 PM   #8
When i modeled both, the smaller unit (AW2000) in a bass reflex gets a very good response with a box volume of 29 litres and a Fb of around 24. It drops slowly/smoothly from 100 hz to an F3 of under 30 hz, if I roll off (3rd order) at 70 hz or so. Great performance for such a small enclosure(if this is correct).
Old 6th June 2010, 09:19 PM   #9
datasheet aw2000 in post 1
gehäuseempfehlung...........box recommended;
geschlossen.......closed (box);
bassreflex........vented (box);
basskorrektur.........bass corrected (with an amp);
diese gehäuseempfehlungen sind nur anhaltspunkte..........these box recommendations are only clues;
the examples are with use of an active bassmodule (am 80) and bass amplified +3.......+4db;
greets
Old 6th June 2010, 09:49 PM   #10
djk is offline djk
djk's Avatar
They both look like nice drivers for a 6th order vented box. They will probably require passive radiators (because of the small box size).
The 8 looks like it would be good in a 15L box, tuned to Fs, with a Q=2 filter at Fs.
The 12 looks like it would be good in a 40L box, tuned to Fs, with a Q=2 filter at Fs.
Candidates for the Darwin Award should not read this author.
Mivoc subwoofers- low bass, great value; whats the catch?Hide this!Advertise here!
About Mivoc floor speaker (big - 2 bass) tungpm Multi-Way 7 31st May 2009 08:49 AM
I Dono whats wrong guys but help would be great besetfreemusic Car Audio 4 10th August 2007 12:22 AM
how can sealed subwoofers produce lots of low fast bass? pkgum Subwoofers 30 11th January 2002 06:31 PM
Great Subwoofers adam73nwo Swap Meet 0 10th December 2001 02:49 AM
Copyright ©1999-2017 diyAudio
