I have 1 peerless xls12" & 1 passive but i can't fine any plans to build with
i'm trying to get plans form stones sound studio i read that using two passives is so much better where do i go |
#2 |
Don't know of any plans, just this application sheet detailing some design considerations: XLS 12" subwoofer | Tymphany
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
thanks GM
It all helps o'm looking on a few web sites alsoRythmik Audio • Subwoofer enclosure plans and DIY Audio projects including speaker and subwoofer designs, to gainclone and other amplifiers Stones Sound Studio -Australia's Hometheatre speaker kit specialist ,RAAL RibbonTweeter Bybee Filter Peerless Fountek Sb Acoustics Shanling Quinpu Visitation Monacor Mundorf Fountek RAAL Peerless Scan Speak Vifa PHL RAAL Nakamichi Shanling Qinpu Audio no the last one stones, I had a good talk with has plans for $110.00au |
#4 |
Check out the page for tapped horn.
William Cowan's Homepage
moray james |
#5 | |
Download Unibox (needs Excel) or WinISD (standalone) and get simulating. If you specify which Peerless XLS and which PR you have then we can sim them too and give advice. Once you have the tuning and enclosure volume designed via simulation, the rest is simply making a box of that internal volume which isn't hard, just some simple geometry. Also head off the Home Theatre Shack where there is an archived section for sub testing, including some Peerless designs as well as a DIY section. HTG and AVS also have active DIY sections with lots of sub builds going on and experience designing and building them. |
| 15" enclosure plans | Smallfaces | Subwoofers | 1 | 3rd June 2008 08:39 PM |
| Full-range enclosure plans depository | GrahamnDodder | Full Range | 0 | 5th March 2005 03:01 PM |
| 1kW 2x12 | rossco | Multi-Way | 4 | 15th March 2004 09:54 AM |
| Enclosure plans for Tannoy H.P.D. | Fred Petersen | Multi-Way | 0 | 5th August 2002 08:43 PM |
