Old 3rd June 2010, 05:48 PM   #1
Default tapped horn for midbass
Can tapped horn play midbass
Old 3rd June 2010, 05:54 PM   #2
PASC is offline PASC  Brazil
Hi!
What do you think of this one (60Hz up)?
William Cowan's Homepage
PASC
Old 3rd June 2010, 06:01 PM   #3
I have two selenium 15sws800 i would like to build two midbass tapped horn for, with some help
Old 3rd June 2010, 10:03 PM   #4
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
What is the lowest frequency you are looking to cover?
Knowing will help as a basis to the design.
Old 3rd June 2010, 10:26 PM   #5
Originally Posted by PASC View Post
Hi!
But aren't those Karlsons?
Y'know "tapped horns" look a bit more like Karlson enclosures each time I think about them. And the underlying theory is just as coherent.
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), Klipschorn mixed-bass woofer w/param. EQ plus 1954 AR-1W or giant OB
HiFi construction since 1956
Old 3rd June 2010, 11:41 PM   #6
frequency range 80hz to 300hz
Old 4th June 2010, 12:52 AM   #7
GM is offline GM  United States
GM's Avatar
Not really, though they can be approximated using T-TQWT theory, ie. instead of a series of resonant chambers folded back on itself, a reverse tapered TL can be substituted. Bottom line, all these different alignments are limited BW band-pass alignments.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 4th June 2010, 01:34 AM   #8
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi soundhead,
Imo, The only way to reach 300 Hz is by using a very constricted throat, not Rek., or by Eq a couple of dB:s..
b
Old 4th June 2010, 02:22 AM   #9
GM's Avatar
Well, on paper it can, but without building one I don't know if its minor 'ringing' would be audible/obnoxious:
GM
Old 4th June 2010, 02:35 AM   #10
GM's Avatar
Missed this, so I agree with bjorno.
GM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Help with a tapped horn. mike james 533 Subwoofers 32 11th November 2009 02:34 AM
Midbass J horn tade Multi-Way 26 19th November 2007 12:33 AM
Page generated in 0.11410 seconds (85.66% PHP - 14.34% MySQL) with 11 queries
