Has anyone got links to a project/product that uses this insane driver? in the blurb it claims "Perfectly at home in new or refurbished horn loaded sub bass systems" however the only info I can find from google searches are people who tried large closed boxes in simulation. The Fs of 30Hz seems an indicator to me that it's not suited for low bass in closed boxes. I am very curious as to the size of a horn using such a large driver, as my own designs using the 12" pd are quite large already!
#2 | |
Large drivers are not required for horns,unless you have a horn the size of a shipping container. See the labhorn (2x12") All you are looking at, its hurting your back and getting drs bills. Instead look at smaller multiples.
http://www.diyaudio.com/forums/subwo...th-thread.html |
#3 |
Yes I know this as I have actualy designed a 12" horn of my own now I am just wondering if anyone has taken on something as insane as this driver in a horn.
#4 |
Load it into HR and use the System designer to spit out a compression horn.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 |
Agree if a refrigerator size T-TQWT is ok! ![]() b |
#6 |
Opus Audio in Cornwall UK have some double 24" reflex cabinets.
They are BIG, but apparently still have a 'fast' sound, and go down to 15Hz! Photo OPUSPOCUS: PA system hire package FOUR - 'Concert Series' Opuspocus have also developed a single 24" reflex cab for portable use! |
#7 |
#8 | ||
I decided to design a ‘home’ 439L T-TQWT with derated max input power as this incredible driver has only (unsurpassed?) 1% 2nd and 3rd harmonic distortion and very little power compression, IMO = benign if played below 100W and the possible passband SQ would peak. The T-TQWT has now an f-3dB at ~17 Hz and is excursion safe at 1 Hz; a sub amp may be used with no input HP filter at all, if one dares. ![]() b |
#9 |
I swear bjorno, you post the best and most complete info
I love how you showed the circular & rectangular mouth options.
#10 |
Geezo peezo! Five full octave pass-band!
GM
| Horn experts - Please help to determine optimal throat size for low-mid horn | pk | Multi-Way | 9 | 19th August 2012 06:29 PM |
| Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background | layertone | Subwoofers | 15 | 23rd January 2010 05:12 AM |
| Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background | layertone | Full Range | 2 | 23rd December 2009 12:51 AM |
| looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P | SkinnyBoy | Multi-Way | 24 | 13th February 2004 05:06 AM |
