Hi there,
I'm using (and loving) a pair of Lowther Acoustas with DX4 drivers. Although I personally actually rather like their bass, friends and family have criticised it as being a tad "polite". So, I am considering trying out a mono-sub in the middle. So, here come the questions which I'd appreciate some views on: 1. According to various views I have seen on the web, combining lowther drivers with subs can lead to problems of relative speed. In other words, "legend" has it that most subs are not fast enough to match lowther drivers. Can anyone suggest a sub design that would be fast enough, other than a khorn which I can neither afford nor build with my limited wood-working skills (and which, in addition, would not really suit the room - need a centre mono sub ideally)? 2. Failing that, has anyone had experiences with using delays to match the speed of different drivers in a system? How do you do it and how much impact does it have on the sound? 3. I am keen to keep the signal that goes into the Acoustas cross-over free. Do you see any problems in the fact that certain frequencies will thus be coming out of both the sub and the main speakers? Thanks! Nikos |
#2 |
Speakerholic
I am curious to know what you mean by a slow driver. AFAIK that's a misnomer. I am wondering if what you're describing is the bloated sound that many powered woofers offer versus the less boomy sound offered by something like a PA driver.
#3 | |
Eventually, I reached the conclusion that it is probably a contrast to the "direct" (again, given lack of a better word) sound that the Lowthers have compared to (the limited number of) other speakers I have tried. Ultimately, I had assumed that a delay between what comes out of the Lowthers and the woofer (albeit one of milliseconds) would occur. |
#4 | |
There's an Aura NS 18" for sale in the classifieds that would be perfect.
Jim J. |
#5 |
A DX4 has a ~0.21 Qts, ergo at a glance your sub needs a ~0.2 Qts 'sub' driver in whatever Qtc sealed or ~aperiodic alignment that most closely matches the Acousta's roll off slope to blend well, i.e. freaking huge if you don't use a Linkwitz-Riley Transformed (LRT) sealed cab and even then probably still fairly large since multiple drivers will be required to get efficiency up enough to keep excursion well within Xmax.
I assume though that you're driving them with a high output impedance, so the driver's effective Qts must be calculated before designing the 'sub' system. Now you know why most sealed, vented sub systems can't keep up with a 'fast' set of mains since folks typically use a single > 0.4 Qts low efficiency driver. I may be missing something obvious, but ATM I can't visualize how adding a delay will help such a Qt mis-match. Delays are about matching up differing phase responses. OK, then you'll need to bi-amp and low pass the sub separately wherever it blends the best with the mains. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#6 |
I think you have the right drivers. If the box is sealed all the better but it needs to be a solid box. Then what your really need is something to flatten out the low frequencies. Low Q is great for control, speed, and output but really does require EQ and a amp with solid bass. If the amp is sloppy there is nothing you can do really. High gain amps with lots of feedback usually but not always have better bass. There are a few different ways to EQ, a second order high pass filter with a Q of 1.5-2 or so set to flatten the sub. Frequency of the filter will be near the frequency of the woofer in the the box, Fb. Good luck!
What the other guy said----Standing on the shoulders of giants. New avatar- no more little array |
#7 |
Id go for small sealed or open baffle
#8 |
How about an infinite baffle sub, while we're throwing ideas around...
Is there any amplifier in particular you'll definitely be driving this with, or are you thinking of buying one...?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#9 |
also, if you dont want any filtering of your main speakers you will have to keep the sub within 1/4wavelength within passband. If you filter low at say 90hz this is much less of an issue (0.95m 1/4wave)
Note that distortion wont be decreased too much if the main speakers are still outputting sub frequencies. if the Qts is low this is less of an issue however. Re: 'fast' I think we are not talking about the rise time, that refers to the high frequency cutoff. Instead we are talking about resonance after the initial impulse due to tuned pipes(ports)also spurious harmonic products,not just the fundamental tuning and perhaps resonating panels,higher up in frequency if the enclosure is large enough. I cant remember the math for the high cutoff rate and effects on transient response. There was a site around with scans of some Olson acoustics graphs. Last edited by neddludd; 14th May 2010 at 07:22 AM. |
#10 | |
Thanks for all the suggestions to everyone btw. |
| THAT was fast | DragonMaster | Everything Else | 0 | 25th August 2006 05:52 PM |
| help fast ! | v1d9uy | Full Range | 3 | 12th January 2006 10:15 PM |
| KlipschHeil! Say it fast! | dshortt9 | Multi-Way | 7 | 16th August 2005 01:44 AM |
| i need fast help | shereen | Digital Source | 0 | 21st June 2005 09:14 PM |
| How fast are 'Fast Fuse' and how to identify? | bigpanda | Solid State | 7 | 22nd March 2005 09:00 PM |
| Page generated in 0.11103 seconds (81.75% PHP - 18.25% MySQL) with 11 queries |
