I've read about and seen many Tapped Horns but have no idea why they work. Are they limited in how high they will go? Cheers.
#2 |
It's a bandpass horn where both sides of the driver diaphragm are used to contribute to the sound. How high or low they will go depends quite a bit on both the driver and the horn design. A good design can get you around 3 octaves - it's a little tricky to get them right.
My own tapped horn uses two Tang Band 8x12" woofers and has a bandwidth of 16-80Hz. Not perfect, but it was a first time effort. It will do above 80Hz, but not with the same sound quality you get in the passband. It's tolerable up to about 100Hz, but I don't usually let it play that high. |
#3 |
I'd like to know if you can mount two woofers in one enclosure and get some impulse compensation? Would this still be 6dB louder than one woofer and do I have to double the crosssections too?
Those rectangular Tangband woofers seem efficient to put in pairs into an enclosure. Last edited by vadi; 12th May 2010 at 07:38 PM. |
#4 |
I haven't really tried too hard in modeling only one of the TB woofers, but I can say they like big boxes whether you use only one or two. I went with two because I thought if I didn't, people wouldn't think I was crazy enough
I did get slightly better modeling results using two for the 16Hz corner I was after, but I'm not sure if that's just because I gave up on only using one due to SPL and Xmax limitations. Mine ended up being 74x42x17" - it's absolutely huge. I did everything I could to get the size down, but those woofers weren't having any of it. Got a design on the drawing table that does the same job at higher SPL in about 60% of the space. I'll leave the impulse compensation part to those a little further down the learning road than I am. I've only tried the tapped horn thing once so far |
#5 | |
You could mount one woofer reversed to reduce some distortion products,frm memory the 2nd harmonic Last edited by neddludd; 13th May 2010 at 02:51 AM. |
#6 |
Yeah, that's right.
I used a similar technique to eliminate 2nd harmonic from my sealed sub - I mounted one driver normally, then one with the magnet outside.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#7 |
Chris661: interesting you mention this, since a sealed box causes 2HD by itself due to the compression of the air. There is an equation floating around which can give you an indication. I think the linkwitzlab thor subpages showed this. Whether or not it matters compared to the distortion of the subwoofer itself is another issue.
#8 | |
Right, to get the extra 3 dB of acoustic gain you have to double the horn's net volume (Vb), i.e. double its cross sectional area (CSA). GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#9 |
Which TB? All that I've simmed were tiny, requiring two drivers just to make them big enough to easily mount the drivers and get adequate acoustic gain out of them.
GM
#10 |
| tapped horn need some tweeking (help) | kornnylike | Subwoofers | 5 | 9th April 2010 10:10 AM |
| Can a Tapped Horn have a negative taper within the horn path? | BP1Fanatic | Subwoofers | 6 | 13th February 2010 06:04 AM |
| Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background | layertone | Subwoofers | 15 | 23rd January 2010 05:12 AM |
| Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background | layertone | Full Range | 2 | 23rd December 2009 12:51 AM |
| Help with a tapped horn. | mike james 533 | Subwoofers | 32 | 11th November 2009 02:34 AM |
| Page generated in 0.10463 seconds (78.65% PHP - 21.35% MySQL) with 11 queries |
