Old 10th May 2010, 01:14 AM   #1
justint is offline justint  United States
Talking Help me have fun with 8 MCM 8's on a subwoofer design
I have 8 of the MCM 8" high excursion woofers laying around and I am looking for a loud and low interesting looking design using at least 4 of the woofers.. ideal performance of the box would be extension down to 30-35hz with 120+ db if that is feasible.. after that give me something fun to test my wood working skills... Just got a new table saw and I am feeling ambitious!!!
Old 10th May 2010, 05:53 AM   #2
what are the specs? 800litres ambitious? You may have enough displacement for open baffle ie less coloured sound with a slow roll off which is meant to sound better.
Old 10th May 2010, 01:38 PM   #3
that might be to large for me.. probobly 600 liters or less would work fine.
Old 10th May 2010, 01:44 PM   #4
GM is offline GM  United States
GM's Avatar
So, what did you decide to do with the Kicker? need loud and low TH design help :)
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th May 2010, 04:03 PM   #5
I have finished the 10" kicker Fury box recuting of the plate and am currently hitting a range from 130db@40hz down to 124@65hz back up to 130@100 hz.. and I haven't had a chance to load the box into the corner behind my tv yet.. Combined with the JBL eon 15's I have running my ears are still ringing from this weekend so I am satisfied.. with that.. I have one kicker CVT left which I am going to keep as a spare for my boat TH that you can look at on the other post and just these 8 8's laying around that I gotta figure something to do with.
Old 10th May 2010, 04:44 PM   #6
jbell is offline jbell  United States
Here's a thread to digest...
Dual MCM FLH
Dual mcm's in series (to keep from blowing them up) is a good idea, and gets a reasonable sized box. Lots of possibilities -- from as small as possible (50liter) tapped, to 300liter front loaded horn.
Old 10th May 2010, 10:21 PM   #7
lol your ears shouldnt be ringing! I find distortion in the midrange appears to make ringing worse too.
Old 10th May 2010, 11:28 PM   #8
Usually by bar close as long as nothing blows clarity is not a huge concern haha
Old 14th May 2010, 02:21 AM   #9
sumaudioguy's Avatar
Use a bigger box so the Q in box is about .5 and then use bass boost to flatten. A high pass filter at like 35Hz with a Q of 1.5-2 would be good. This keeps out of band signals at bay and flattens the response electronically rather than peaking up the mechanical system of the driver. Good luck!
What the other guy said----Standing on the shoulders of giants.
New avatar- no more little array
Old 14th May 2010, 07:25 AM   #10
I used to deafen myself with a martin-audio system in a bar I used to frequent many times. The 18" 1kw WSX horn subs were great, eventually about 4am the mids would get turned up too high though as peoples ears adjusted to the loudness!
Whatabout 2x8" sealed boxes. I prefer smaller portable multiples, harman have some audio whitepapers on room response and multiple subs.
Two 10's or four 8's? eastman474 Car Audio 10 5th January 2010 12:24 AM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
Rokit 8's Madmike2 Swap Meet 1 21st August 2005 07:53 PM
Looking for 55-1875 MCM 18" woofer box design lXxAndyxXl Multi-Way 7 28th September 2004 03:32 PM
MCM Focal sub clone used in Pass design el'Pipeo for $90! JCoffey Multi-Way 0 12th December 2003 02:37 PM
Page generated in 0.09947 seconds (78.22% PHP - 21.78% MySQL) with 10 queries
