Hello
i am totally new to building speakers and need some help from you guys I am building a case for the Dayton 12" woofer. Dayton Audio - Dayton Loudspeaker - Loudspeaker Drivers - Titanic MKIII Subwoofers The VAS is the required volume right? 2,61 ft³ = 0.056633 m³ That means i need a case with 56.6 litres? I wanna have a ported case for the extra deep Hz. I anyone has a caseplan, i would the be much gratefull and ofcourse for any help and guidelines Cheers |
#2 |
+1 i'm interested in building acoustic systems. any tips, links would be useful.
#3 | |
This site has a calculator program you can use. Subwoofer Box Enclosure Design Calculator - Sealed Ported Bandpass Closed Vented I entered some T/S parameters and the 12" woofer needs a 2.3 cu ft. enclosure. With a 4" port, it needs to be 27 in. long. F3 point is 22Hz, so it gets plenty low. Be sure to set the units correctly with this program. Its limitation is that it just gives one fixed output. You can't tinker with box volume and port length to see how it affects performance. You might need a larger port because of the noise called "chuffing" However, the length of the port means that you will have to "fold" (elbows and such) it. It might be wise to use a 3 cu ft box due to the volume consumed by the ports. |
#4 |
Thank you for the answer, but then caluclations it only need 65 litres enclosure? Is that right?
#5 |
Note that a small enclosure with a low tuning and a fixed port diameter equals a very long port no matter what woofer.
I would consider a small sealed box or a moderate sized ~75litre ported enclosure tuned near 36hz,which may well give a hump in the midbass around 55hz. |
| Driver to build an good subwoofer. | samsagaz | Subwoofers | 10 | 11th September 2006 04:08 PM |
| Want to build small subwoofer | c3ham | Subwoofers | 76 | 7th September 2006 08:26 AM |
| Build a subwoofer with these drivers? | mazeroth | Subwoofers | 7 | 30th August 2004 07:10 PM |
| Looking To Build SPL Subwoofer | Mista_Bishi | Car Audio | 12 | 13th May 2004 06:55 PM |
| how to build a subwoofer? | nicovdk | Subwoofers | 7 | 26th December 2002 02:11 AM |
| Page generated in 0.08042 seconds (72.95% PHP - 27.05% MySQL) with 10 queries |
