Old 7th May 2010, 06:51 AM   #11
AllenB is offline AllenB  Australia
Horn parameters more significant than driver parameters....that may be the salient point.
Could the LT be used to allow a smaller vented box to be used? Noting that the vented box is 4th order, could I take a transfer curve of the desired and actual responses and shave this off, retaining the desired transient response or better?
Old 7th May 2010, 07:27 AM   #12
Shaun is offline Shaun  South Africa
Shaun's Avatar
I think you should not restrict yourself to "Linkwitz Transform", as this describes a very specific application. "Equalisation" is probably more suitable, as it is more generic, not being limited to a specific filter type.
Keep in mind that below the port resonance the driver quickly runs out of excursion, so any boost applied here must be chosen judiciously.
Check out this article. Active Equalization of Loudspeakers. It uses SoundEasy loudspeaker design programme but the discussion is, I believe, relevant to what you seem to be contemplating.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 7th May 2010, 07:49 AM   #13
OK, reading that now. First thoughts though are that I expect a LT, when it undoes a rolloff, to also undo the phase response.
Old 7th May 2010, 07:56 AM   #14
Shaun's Avatar
It certainly affects the phase response, yes. "Undo" is not really what it does. I guess one can say that it provides a complimentary compensation (i.e., equalisation) but, again, only over a limited range.
Shaun Onverwacht
Old 7th May 2010, 04:29 PM   #15
Did it Himself
richie00boy's Avatar
It transforms the phase response to what the chosen Q represents. Regarding your idea on the vented box, you may be able to achieve something but it will be difficult to work out and usually shrinking the box size in a vented design means you end up with a port too big to fit inside the box without some serious woodworking skills.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 10th May 2010, 12:35 PM   #16
kipman725's Avatar
Send a message via MSN to kipman725
phase response shouldn't matter apart from at crossover points or if so extreme a large group delay results. The only way I know of for correcting group delay is by delaying the signal to the other speakers by an equal amount using a computer/dsp.
Old 10th May 2010, 01:43 PM   #17
Shaun's Avatar
No. Group delay is a function of the phase reponse. Read this .
Shaun Onverwacht
Old 14th May 2010, 11:08 AM   #18
speaker dave's Avatar
Originally Posted by kipman725 View Post
ESP - The Linkwitz Transform Circuit
it's just an EQ curve which is the inverse of a closed box speakers roll off so allows the speaker to operate with flat frequancy response at lower frequancys. It does nothing to the actual speaker just changes the input to the speaker.
This was the right answer to the original question. the Linkwitz circuit (or the KEF Kube) does nothing to change the parameters of the woofer, it is just a precise method of "undoing" the combined (woofer and box) response you have, and replacing it with a desired response. You haven't changed the parameters of the woofer and placing that woofer in a new box will get you a different response that the EQ will no longer suit.
If I recall correctly, horn drivers need to be low mass for bandwidth and high Bl. You can still use a "wrong" woofer and equalize the result, but the needed EQ won't have anything to do with what EQ worked for the sealed box.
Here is a question for the real experts out there: lets say we use negative output impedance to lower the effective Q of the woofer. Would that transfer from box to box? Can we add external network components to simulate higher mass? Will that transfer from box to box?
David
Old 14th May 2010, 08:57 PM   #19
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by speaker dave View Post
..Here is a question for the real experts out there: lets say we use negative output impedance to lower the effective Q of the woofer. Would that transfer from box to box?..
Hi David,
Yes it would.
Yes but how effective depends on the driver in use among other aspects. See:
ACE-bass amplifier design
and
Enclosure for high Q driver
b
Old 17th May 2010, 07:19 PM   #20
Originally Posted by bjorno View Post
Hi David,
Yes it would.
and
b
Ah, yes, ACE Bass. I had forgotten about that. A clever way to "transform" the woofer.
Note that at the woofer terminals, the acoustical response of a woofer to an electrical input doesn't change. Still, the amplifier/woofer combinations do make the woofer appear to have different parameters and react accordingly when placed in different cabinets.
David
My CHR-70+DSP Linkwitz Transform experiment (4" driver playing flat to 20hz!) tresch Full Range 54 30th May 2010 10:46 PM
My Linkwitz Transform wants to violently rip my driver to bits mikee55 Subwoofers 14 15th January 2007 12:49 PM
linkwitz transform peace brainerd Subwoofers 4 31st January 2006 01:13 AM
Linkwitz Transform? Aunkst Chip Amps 6 28th March 2004 11:59 PM
Linkwitz transform ciruit applied to midrange driver Beggar Multi-Way 6 8th August 2002 11:16 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
