mini el pipe o : Raptor 6 in a tube
I get 2 Raptor 6 and would like to put them in tube to get 2 mini el pipe O:D.
resonance is 53 Hz so the 1⁄4 wavelength
is 1.55 meter, right ? (it's about 5.18 ft).
the tube will be 5 ft long and 6 in diameter, and the question is :
is the volume ok ? it's 23.8 liter.
Thanks,
Blo
Technical Facts Speakers
Impedance (Z)
Resonant frequency (fs)
53Hz
Max. frequency range
f3-800Hz
Music power
300WMAX
Power rating (P)
100WRMS
SPL (1W/1m)
88dB
Suspension compl. (Cms)
0.38mm/N
Moving mass (Mms)
23g
Mech. Q factor (Qms)
2.2
Electr. Q factor (Qes)
0.43
Total Q factor (Qts)
0.36
Equivalent volume (Vas)
6.9 l
DC resistance (Re)
3.4Ω
Force factor (BxL)
7.6 Tm
Voice coil induct. (Le)
0.6mH
Voice coil diameter
25mm
Voice coil former
KAPTON
Linear excursion (XMAX)
±9mm
Eff. cone area (Sd)
113cm2
Magnet weight
850g
Weight
2.4kg
I'm using a mathcad template written by Martin J. King to model your driver in a transmission line, I tried 1.55m initially but it requires both more fill and a carefull application of said fill to not sound boomy, 2m with a little stuffing was a sweet spot I chose from experience that will go lower and be less tempremental to get good results out of. (I make TL enclosures for a living, allbeit for car audio but still)
The volume isn't something I concern my self with so long as it fits where it needs to go and the area of the line isn't too crazy compared to the SD of the driver (1.6:1 in this case being more or less ideal), it's not critical like it is in a vented enclosure.
Hi all, .. How does it sound?..
Hi Rascalito,
If ever built the Op suggested pipe would not sound good at all as the pipe volume for this driver would be too large.
Should be at or below 2 x Vas if in a Nd pipe to allow sensible amount of stuffing to cure the very peaked response.
b:)
