I am planning 2 build a pair of subwoofers for my PC speaker system. I am thinking of using combined vented system [maximally flat(QB3) and extended Bass system (EBS -3dB)]. This sub will be used in a medium sized room. Driver size i will choose maybe 8 inch for QB3 and 10 inch for EBS -3dB. The drivers will share a single box but different chamber (separate QB3 and EBS chamber).
Will this design (combining EBS and QB3) give any advantage to Bass response other than extended bass? Or i should go for a simple pair of QB3 or EBS -3 alignment? |
#2 |
I am not sure about the exact question you asked but one thing I noticed when I did subs for my PC system was that when I had the subs next to my desk, I could barely hear them but my wife in the other room always complained that the subs were turned up too high. So, I moved the subs away from me to the back of the room and I could then hear and feel them working without turning them up so high.
#3 |
If you want max flat vented you will need a driver with a free air Qt of .383 or very slightly less. Make sure the vent is at least one third the area of the driver.
MCM Electronics has an 8 inch true woofer pretty cheap and works well for such a small woofer in a sealed box.
What the other guy said----Standing on the shoulders of giants. New avatar- no more little array |
#4 |
Mixing the alignments wont give you a bonus, you simply get the mean value of both responses as the final response.
#5 |
Sealed box is 40 Hz and ported box is 34Hz both butterworth. Scale is 10-200Hz ±10dB. 6dB was removed from the total output to normalize to 0dB. Looks like the pair is no better than the seal 40Hz one by itself with slightly better phase response.
#6 |
I have heard of dual Vent system, where both the ports are tuned to different frequencies to get the required curve. I guess this might suffice your need. check on google if you find more information on this.
There is always a first time.... |
| Subwoofer for B3S system | BMD | Subwoofers | 16 | 3rd January 2008 12:23 AM |
| how to connect a non powered subwoofer to a stereo system without a subwoofer output | JSD777 | Multi-Way | 4 | 20th September 2005 03:19 PM |
| Stereo system with Subwoofer, How to do it? | py | Everything Else | 5 | 13th January 2005 07:25 AM |
| Tempest subwoofer for sale (Adire alignment) | Darren_T | Swap Meet | 3 | 3rd April 2003 05:49 PM |
| Need subwoofer/lspCad gurus to review my sub alignment choice | alphaGeek | Subwoofers | 0 | 12th October 2002 01:40 AM |
| Page generated in 0.08077 seconds (85.65% PHP - 14.35% MySQL) with 11 queries |
