plz clarify my doubts abou following:
1) what is mean by THD 2) what is mean by signal to noise ratio 3)Alteclansing(fx5051) have a Signal to Noise Ratio of @ 1 kHz input: > 75 dB and Edifier have >85DBA which one is good? |
#2 |
Banned
Total Harmonic Distortion is a measure of how much inaccuracy an amplifier introduces into a signal. Smaller number is better.
All electronic circuits suffer from internally generated noise. This is audible as hiss in an audio amplifier in some cases, particularly if the volume is turned up and there is no signal. Signal to noise ratio tells you how much hiss to music there is regardless of volume setting, so it's a measure of amplifier quality usually expressed in dBs, the bigger the number the better. You cannot compare dBs and dBAs w These are very basic explanations, you could probably have worked it all out for yourself with a bit of googling. |
#3 |
frugal-phile(tm)
To expand what wakibaki says.
THD is a "sum" that collapes the spectrum of harmonic distortion into a single number. The only scientific studies extant (Geddes) indicate that this single number has little correlation to sonics unless it gets quite large. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 | |
Jim J. |
#5 |
thanks
#6 |
Be ware of numbers with weighting. Like dBA. Well especially with A weighting as it hides even huge amounts of 50Hz noise, 30dB in fact relative to 1kHz.
See Ponderaciones A, B y C / A, B and C weightings < Referencias de Audio Profesional / Pro Audio Reference Google seems to report it as malicious content for me at the moment though. |
| Marketing Terms - in plain cruel words! | halojoy | Everything Else | 106 | 27th June 2007 09:10 AM |
| DCX 2496 question laymans terms (aka ignorant mans terms) | cmckasty | Digital Line Level | 1 | 11th May 2005 03:03 AM |
| Lobbing What is it in layman's terms? | mrteleportal | Multi-Way | 5 | 24th November 2004 10:00 AM |
| Page generated in 0.08292 seconds (74.32% PHP - 25.68% MySQL) with 10 queries |
