18sound 18lw1400 - diyAudio
Old 21st April 2010, 03:01 AM   #1
Default 18sound 18lw1400
hey i have 2 18lw1400 and i wanted to know what would be the best cabinet design for these subs?
Old 21st April 2010, 04:40 AM   #2
col is offline col  Australia
col's Avatar
lucky you.... did you look at designs on the 18sound website? What is your application?
col.
http://www.minirig.org.au
Old 21st April 2010, 07:54 AM   #3
Go back to page #3 under check this design out ,to see if you like that horn loaded design
Old 21st April 2010, 03:12 PM   #4
i tried the one on the 18sound website but it doesnt seem to project. i looked at that design before on check on this design before i like the idea but its in 2 parts and really big its about 53 in height i believe.
Old 21st April 2010, 07:21 PM   #5
Do you have more information on what, more or less exactly, you're looking for? Like how low does it need to go, what do you use on top, how large can it be, how much power do you have for it, style of music could give a hint also.
The 18LW1400 is pretty allround due to it's parameters, so a lot is possible.
Best regards Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 21st April 2010, 10:57 PM   #6
Well the type of music is reggae and I'm using the crown xti 2000 bridged. The cabinet on the website doesn't seem to give a good thumb. The sound seem to deminsh when u step away from it. I'm open to any design as long as it's not too huge
Old 21st April 2010, 11:06 PM   #7
An it must be mobile!
Old 21st April 2010, 11:25 PM   #8
I would use it in a closed enclosure without a doubt.
Plenty of headroom. But indeed, it depends on your application.
Old 22nd April 2010, 11:42 PM   #9
What design are you talking about exactly?
If it's either the front loaded design (basreflex) or the double manifold/band pass, make sure the speakers are "in phase" . When they're not in phase, the sound deminishes very fast as you describe, you can check this by reversing the polarity of one of the speakers, if the bass reduces in strenght after you've done this, they were in phase, if the bass gets more powerfull they were out of phase.
Also the 18LW1400 needs quite a bit of power to get going, don't give up on it too soon.
What crossover frequency do you use between the subs and tops? There are more power full yet quite compact designs out there but these generally need a crossover between 80 and 100 Hz, to sound their best.
Best regards Johan
Old 23rd April 2010, 12:21 AM   #10
col's Avatar
Reggae.... easy, scoop bins. Look on speakerplans.com.
col.
18sound 10NMB420 - any experiences? Defo Multi-Way 3 3rd August 2009 12:14 AM
18sound 12NDA520 (a.i.c.) xpert Multi-Way 0 24th May 2009 08:50 AM
18sound 21LW1400 exurbia Multi-Way 2 11th November 2008 03:03 PM
18Sound midbass/midranges, opinions? thadman Multi-Way 3 17th February 2008 10:17 PM
18Sound 18LW1400 vs JBL 2242H 2100 Subwoofers 20 19th December 2007 04:06 PM
Copyright 1999-2017 diyAudio
