Old 20th April 2010, 03:11 AM   #1
Default Electrovoice 4-18" bass bin
Does anyone remember a sub electrovoice used to make many years ago,it was about 45" by 45" by 30" deep. It had 4-18" subs all loaded with their magnets almost touching in a cavity that was open to atmosphere,and the front of each woofer was loaded into it's own ported box ,I guess all the 18's had their polarity reversed?
Weird configuration but I have been in a club and at parties where they were used .The bass was so tremendous with 4 of these cabs,i've not heard anything close since then.
If you have a model # it would be much appreciated. EV's site has been down for a while and I can't find any info.
Old 20th April 2010, 03:52 AM   #2
Audio Junkie
Zero Cool's Avatar
You mean the EV MTL4??
Old 20th April 2010, 03:53 AM   #3
danielm is offline danielm  United States
MTL-4. Heavy mothers.
http://www.osmondelectronics.com.au/...TL-4%20EDS.pdf
Old 20th April 2010, 04:11 AM   #4
Exactly holy crap,thanks.I've always wanted to build some. Thanks alot!
Old 20th April 2010, 04:20 AM   #5
With these newer drivers that handle twice the wattage of those specs this box should kick some serious *ss. Imagine 4 -18" Peavey lo-riders running off a Crest CC5500 in that box!!!!!! Can't wait to get some 5 by 5 baltic!
Old 20th April 2010, 10:00 AM   #6
djk is offline djk
djk's Avatar
"Imagine 4 -18" Peavey lo-riders "
Drivers won't fit.
Anyone that doesn't own a forklift and a big straight truck is insane to contemplate these things.
A better way of doing things:
Candidates for the Darwin Award should not read this author.
Old 20th April 2010, 10:27 AM   #7
AKN is online now AKN  Sweden
Enjoy good sound
AKN's Avatar
But why not mount the drivers as you do djk? Reverse two of the drivers in that EV MTL-4 and get the same distortion cancellation. I suppose a lot more drivers will fit as well.
/ Anders
Old 20th April 2010, 01:13 PM   #8
Default MTL Mini
I built a mini MTL a about 17 years ago using cheapo 8" drivers. Sixteen of them!
Two holes per side, each hole had two drivers "clamshelled". This way we got by with a smaller box. Only eight drivers were visable looking inside at the magnets. I recall the box being 20" deep and not much more than that square.
The cheapo 8s were good for maybe 100 watts but we could throw some serious power at that box without seeing much power compression due to all those voice coils.
Old 20th April 2010, 01:19 PM   #9
Drivers won't fit.
+1
My back prefers many small boxes.
Plus, with a bunch of small subs you have the option of making steerable arrays depending on placement.
Old 21st April 2010, 01:34 AM   #10
djk is offline djk
djk's Avatar
"I suppose a lot more drivers will fit as well. "
Might. The volume is only about 3.3 cu ft per driver though, most 18s like more than that. The ports are also quite small, EV data showed them going into compression and changing the box tuning at high power levels. You are still left with moving them.
The design in my photo uses a long x-max 15, which has more total displacement than an EV 18. The box is easier to construct, is about 4 cu ft per (net) driver, has bigger ports, and can be moved by one person with a two-wheeled hand truck.
"My back prefers many small boxes. "
One of the stage hands that moves that PA is female and weighs less than 100lbs. I've seen her unload a bass cabinet from the cube-van, move it up stairs, and stack it, all by herself.
"Plus, with a bunch of small subs you have the option of making steerable arrays depending on placement. "
The guy who owns that rig has 12 low-end boxes and 8 mid horns. He can build a formidable stack, cardiod bass if he desires. He owns 6 of the Crest V1500 as shown.
Single 18" Bass Bin - Plans & Ideas nawtychesco Construction Tips 2 16th March 2010 11:08 AM
Home built bass bin with Fane 600WRMS 18 inch speaker. nigelwright7557 Swap Meet 0 21st June 2009 01:06 AM
Tapped Horn for 18" bass angeloitacare Subwoofers 14 28th March 2009 07:37 AM
32" bass bin MC ISSCEE Subwoofers 1 13th May 2004 01:36 PM
Page generated in 0.10201 seconds (80.35% PHP - 19.65% MySQL) with 11 queries
