Old 15th April 2010, 09:41 PM   #1
Question What to do with 2 volt b2500.1???
Hi all,
Newbie here, long story cut short, last year i upgraded the volt woofer in my rel storm mk1 with a volt 2500.1 and it worked fine.
So i built an enclosure for the original volt that was in the rel but never finished it (no amp),
so then i see a secondhand volt 2500.1 at a good price and i bought it, so now im considering using the 2 volt's 2500.1 in a new enclosure but haven't got a clue were to start, measurement etc.
Can i lower the Hz with longer ports or are woofers designed to go to a set Hz?
Can anyone give me some much needed info?
cheers
Rob
Old 15th April 2010, 10:36 PM   #2
Did it Himself
richie00boy's Avatar
As you seem to be a novice it's probably best you simply copy the design of the cabinet you already have. You may be able to trade dimensions, but keep the same volume and port diameter and length.
Unless you really want to get into the design side of things...
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 15th April 2010, 10:44 PM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by Robert xXx View Post
Hi all,
..Can i lower the Hz with longer ports or are woofers designed to go to a set Hz?
Can anyone give me some much needed info?..
cheers
Rob
Hi Rob,
Agree with richie00boy,and it's kind of a tricky driver..
See the submitted picture. Then visit this thread:
TL Enclosure Design
b
Volt B2500.1 or ATC SB75-234SC? mpa Multi-Way 5 11th April 2010 02:44 PM
Comparison of Volt B2500.1, B250.8, RV3143 and S/S 25W8565-01 jheoaustin Multi-Way 58 8th January 2009 04:25 PM
Switching 230 Volt Transformer to 120 Volt OMNIFEX Parts 10 6th April 2008 04:34 PM
Volt B2500.1 Enclosure schmeet Subwoofers 4 2nd April 2008 05:58 PM
12 volt DC to 9 volt AC eRiCdWoNg Parts 10 18th April 2004 01:52 PM
Page generated in 0.08018 seconds (72.13% PHP - 27.87% MySQL) with 11 queries
