I am simulating a 30 Hz Tapped Horn (please see attachments) for a friend who needs a mono sub to be placed between his horn satelites. The sub is meant to be placed againt the back wall. The desired frequency range is 30-100 Hz. The driver will be a 15" Eminence Definimax 4015LF. I have tried to move the 'high frequency peak' as far up in frequency as possible. The sub will probably be run by one of the larger plate amps. I would be really pleased if some of you would run a 'sanity check' on the simulation before my buddy finally makes saw dust! Thanks a lot! Best regards Peter |
#2 |
Generally said, it looks fine. Personally, i try to avoid having a deep cancellation right above the passband of the woofer, as i think it will make the integration with the mains difficult, not even speaking about the horror of realizing that it is a few hz deeper than simulated and cutting into the passband. Although i have to say i never tried such a dip-thing, so this is only theoretically important. With all the tapped horns i have build so far, the high frequency spikes you see in the simulation are not present in the real measurements, so using the dip to reduce the peaks is not necessary. Also, i think none of tom danleys horns use such a dip.
EDIT: You can half the S1-S2 segment in length, since the midpoint of the woofer is where S2 is. This should reduce the dip. Also, you could try a little higher compression ratio, ie make the S1/S2 values smaller, maybe down to 300-400, which would equal a compression ratio of 2-3, which should be safe and get you a little more output. Last edited by MaVo; 10th April 2010 at 10:19 PM. |
#3 |
A few comments:
1) S3 and S4 will be closer to 2000 or 3000 in reality - your current S4 isn't even the size of one 15" driver. 2) L12 and L34 will probably be a little shorter in reality. All of my designs seem to love a short L34, albeit I work with sometimes less-than-ideal drivers 3) lol @ the WGA crack on your desktop |
#4 |
Hi Mavo and Letsbangout,
Thanks a lot for your thoughtful suggestions! I will try out a few more simulations with these in mind. Best regards Peter |
#5 |
Hi Mavo & Letsbangout,
I have made a new simulation with reduced L12/L34 and with higher compression (due to larger mouth) in order to: 1. reduce the magnitude of the dip, and 2. to increase sensitivity Does this look more sensible? Thanks a lot! Best regards Peter |
#6 |
@ letsbangout: With a mounting depth of 17cm and a diameter of about 38cm the minimum value for S3 and S4 should be 646cm².
@ pk: I spoke about reducing the S1 sliders value... but maybe that would need a 4 segment horn to work properly. You could just keep it that way and it would be fine. |
#7 | |
Mavo: About 'keeing it that way' - did you refer to my last simulation? Thanks! Best regards Peter |
#8 |
Hi Peter,
Compare with my simulations: b |
#9 |
Your last looked better than the first. I think its good.
#10 |
| 38 hz tapped horn, volvotreter | radman12 | Subwoofers | 15 | 7th December 2009 05:13 PM |
| Horn Design - Sanity Check | deiksac | Multi-Way | 121 | 12th October 2008 08:09 AM |
| Midrange Horn Sanity Check | CLS | Multi-Way | 3 | 25th April 2008 11:28 AM |
| JX92S MLTL Alignment Sanity Check Request | rdf | Full Range | 9 | 29th May 2006 01:44 AM |
| Front loaded horn sanity check | Volenti | Multi-Way | 9 | 14th January 2006 05:50 PM |
| Page generated in 0.10987 seconds (77.08% PHP - 22.92% MySQL) with 11 queries |
