Old 8th April 2010, 10:45 PM   #1
FlipC is offline FlipC  United States
Default AC power question - suited for here!
OK
So I have been after these people to let me know what type of connection was available to hook up to (for this Saturday!) as I knew they had more than standard 120 outlets.
Well they took pics.(yesterday!) Those were blurry and over saturated due to flash. BUT it looks like an L21-30 receptacle. And then was told (today) it was 220v 3 phase. So a common mistake and will assume it is 208 3 phase as it is definitely 5 wire so it wont be 240 single phase.
Anyway. I found 2 places in town who have
the L21-30 plugs but no one has any 6/5 cable. One place had 12/5 but that wont cut it. So I am thinking since my distro can be wired for either 120/240 single or 208v 3 phase. Couldn't I just use a 6/4 cable and not use one of the leads on the plug? Effectively wiring the distro as a 240 ?
Distro is the Furman ASD 120.
Old 9th April 2010, 10:49 AM   #2
djk is offline djk
djk's Avatar
I use 6/4 and hook to two hots, neutral, and ground. I use a clamp-on ammeter to see how well the phases are loaded. Just be careful and do not hook anything to the wild leg in a three-phase open delta system (still common in the Midwest USA).
Candidates for the Darwin Award should not read this author.
Old 9th April 2010, 07:54 PM   #3
I agree with your assessment - #6 / 4 conductor cable and wiring the Furman for single phase _should_ get it. However, check and recheck with your RMS voltmeter and make sure it's not something whacky like 277v. I would think that you're right on the money to assume that you'll get 208v from leg to leg.
Given that much power, I'm curious what you're planning to run. Do you have pics?
Old 11th April 2010, 03:04 AM   #4
Well
more power than needed is a good thing.
Was 208. Something went on sequence up. I avent used this Furman yet. Only had it hooked up to 120 to test after replacing some varistors. So ...
Oh well time to look it over completely.
Oh
event was a prom.
8-10K room with 25 feet ceilings. 4 of the Apache H15s I built on Monday/Tuesday. My 4 mini clones, and 8 SB 15's (2 ways). Apaches on EP4K stereo. Minis 2 each on 2 more Ep4s Mono. Then 2 Crown XLS 602s running stereo for the tops (4 ohm per side)
Plus full lighting rig.
Plus video ...
See if ANY OF THE PICTURES TURN OUT .. MICROPHONE POPING... uggh later
Robust Power Supply PCB suited to hi-quality amplifiers RyanW Solid State 58 17th April 2008 12:34 PM
Balanced ac power question John C Power Supplies 1 5th November 2006 11:54 AM
High Freq. AC Power for Filaments of 300B SE Power Amp? snoopyma Tubes / Valves 6 3rd January 2004 06:21 PM
PS question- Need to get 20V AC from 60V AC - w/o Trafo lgreen Pass Labs 9 2nd January 2004 10:31 AM
AC/DC power supply question... Yoda Solid State 6 10th August 2001 01:52 AM
Page generated in 0.09265 seconds (64.87% PHP - 35.13% MySQL) with 10 queries
