Old 8th April 2010, 08:45 AM   #1
Default which driver for a sub
In the last i would say 3 years i have managed to blow up two sub drivers .
shivas & a peerless xls 12 inch . both my own fault .
I am looking at using a Dayton driver .
I am after some opinions on which is the better driver Dayton Reference or the Dayton Titanic MKIII. or maybe a reference 15 inch ?
In a medium to small box . it is for use both H/T & music
Old 9th April 2010, 10:14 AM   #2
MaVo is offline MaVo  Germany
You could use a pro driver, Eminence for example. They are harder to blow up.
Old 9th April 2010, 03:51 PM   #3
sumaudioguy's Avatar
The box type is not mentioned or the mode of failure. Over excursion or overheat?
You may be trying to get bass using small ports which does not work. Used a sealed box or a port that is at least 1/2 the surface area of the active driver. Ports much smaller than that will go into power compression long before the maximum output of the driver is reached leading to cranking up the bass yet no increase in low bass output. I never use ports because by the time a big enough port is in the cabinet there is room for two active drivers.
Voice coil diameter is a fair measure of power handling with a bigger voice coil handling more power. These two will make bass and handle reasonable power in small 2-3 cu ft, sealed cabinets with 2.5 inch voice coils.
Parts-Express.comayton RSS390HF-4 15" Reference HF Subwoofer 4 Ohm | subwoofer rss390hf-4 15" subwoofer dayton reference rs sub dayton loudspeaker
Parts-Express.comayton RSS390HO-4 15" Reference HO Subwoofer 4 Ohm | subwoofer rss390h0-4 15" subwoofer dayton reference rs sub dayton loudspeaker
Ideal voice coil size for a 15 is near 3.75 inches but those are only available in pro speakers designed for vented cabinets usually near 40Hz.
What the other guy said----Standing on the shoulders of giants.
New avatar- no more little array
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
Base driver to suit ESS Heil driver gerado Planars & Exotics 6 1st August 2007 07:56 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Driver/ driver configuration improve soundstage width andy2 Multi-Way 6 16th June 2005 08:47 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Page generated in 0.07623 seconds (70.57% PHP - 29.43% MySQL) with 10 queries
