Old 7th April 2010, 02:21 PM   #1
Default tapped horn need some tweeking (help)
kornnyta.txt
Can someone pimp this out for me
Freq range 20hz to 90 Db 125 and up
Old 7th April 2010, 03:29 PM   #2
MaVo is offline MaVo  Germany
would be easier to judge if you posted screenshots of the parameters and the response... i must admit i am too lazy to dial in all those numbers.
Old 7th April 2010, 04:21 PM   #3
"i must admit i am too lazy to dial in all those numbers."
Considering that the only thing you have to do is import it into hornresp makes you really lazy. Took me 20s.
Now, 2000L??? Why???
Do you really need 125dB 2pi?
Maybe you should consider a different driver or a few smaller boxes.
You should really sit down and define your goals and needs. Then we can help you do something about it.
Old 7th April 2010, 04:25 PM   #4
David some just said the same thing to me
so iwas thinking about scoop or FLH
Old 7th April 2010, 04:26 PM   #5
I am open for ideas
Old 9th April 2010, 10:10 AM   #6
Hehe, thats the right attitude if your asking for help
Didnt even know about a import function.
tapped horn gods kornnylike Subwoofers 2 6th April 2010 04:43 AM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Help with a tapped horn. mike james 533 Subwoofers 32 11th November 2009 02:34 AM
Page generated in 0.07651 seconds (71.84% PHP - 28.16% MySQL) with 11 queries
