Tapped horn need fixing - diyAudio
Closed Thread
Old 6th April 2010, 08:09 PM   #1
Default Tapped horn need fixing
Can someone look at this tapped horn and tweek it better for me
freq range 20-100 Db 125 and up
connie horn.txt
Old 6th April 2010, 08:38 PM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi cornylike,
You exported the wrong script. At the main HR screen 'File' pulldown menu click 'Export' then Hornresp Record..
b
Old 6th April 2010, 08:55 PM   #3
Thanks man
see below
kornnyta.txt
Old 7th April 2010, 02:51 PM   #4
freq range 20-100 Db 125 and up..
Hi kornnylike,
IMO: The Ciare 18.00SW-8 is IMO not well suited to be used in a small TH at 20 Hz and if a large TH is tweaked out and built: to maintain good soundstage SQ: an equalizer for the sub FR and digital delay lines have to be added in series with the mains.
b
Old 7th April 2010, 02:56 PM   #5
so Bjorno what can i do to make this speaker work
Old 7th April 2010, 03:01 PM   #6
Look for an another driver..
Old 7th April 2010, 03:04 PM   #7
Bjorno Can they work in horn loaded
Old 7th April 2010, 03:13 PM   #8
Yes,Which would be a better use for the Ciare18.00SW: a FLH and closed rear might be good but the sheer size of the horn will be very big.
Old 7th April 2010, 03:17 PM   #9
Bjorno the horn size is no trouble
Can you work out for me
what do you think of scoop bin for this speaker
Old 7th April 2010, 03:41 PM   #10
Bjorno the horn size is no trouble..
Are you sure? Scoop bin:
b
Closed Thread
Help with a tapped horn. mike james 533 Subwoofers 33 4th January 2013 11:25 AM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Copyright 1999-2017 diyAudio
