Can someone look at this tapped horn and tweek it better for me
freq range 20-100 Db 125 and up
View attachment connie horn.txt
freq range 20-100 Db 125 and up..
Hi kornnylike,
IMO: The Ciare 18.00SW-8 is IMO not well suited to be used in a small TH at 20 Hz and if a large TH is tweaked out and built: to maintain good soundstage SQ: an equalizer for the sub FR and digital delay lines have to be added in series with the mains.
b
Thread closed. We don't need two so similar from the same person.
See here: http://www.diyaudio.com/forums/subwoofers/164674-tapped-horn-need-some-tweeking-help.html
- Subwoofers
- Tapped horn need fixing
