My transmission line subs 4-21"
Old 8th April 2010, 06:43 PM   #21
ajhockett is offline ajhockett  United States
here is the spec sheet
Old 8th April 2010, 07:58 PM   #22
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
http://www.pyleaudio.com/manuals/PDW21250.pdf
Old 8th April 2010, 08:15 PM   #23
In the spec sheet that u just posted it says the useable range is from 45-1.7khz... They play real nice down low. Maybe it's the transmission line enclosure... Any thoughts?
Old 8th April 2010, 11:37 PM   #24
hornloaded is offline hornloaded  United States
In the PDF it says the xmax is 9.0mm. They dont specify if that is one way or peak to peak though.
Old 8th April 2010, 11:40 PM   #25
its one way
Old 9th April 2010, 12:53 AM   #26
Well 9mm one way is pretty darn good then. I bet 4 of those are devastatingly loud in your room!
Old 9th April 2010, 01:01 AM   #27
i had electrician over this morning to pull another circuit for my sub amp(s) they didnt believe me that I was popping the one that was already there so i had to show them. its much more powerful now. I just ordered 3 more of these subs, 1 to replace one that I fried today, and 2 to make 2 more TL subs with. That will put me at 6 total. ill be happy there. (for now)
Old 9th April 2010, 01:34 AM   #28
Andrew Eckhardt is offline Andrew Eckhardt  United States
Those two spec lists tend to indicate that Pyle has trouble making these woofers for any specific purpose. According to one sheet it's a pretty cool sub driver and according to the other it's not good for anything but 70's disco, Really Loud.
Old 9th April 2010, 01:38 AM   #29
Which is which?
Old 9th April 2010, 01:45 AM   #30
Well usually anything with a qts well below 0.2 has most of the coil already in the gap and a very large magnet to cone ratio. This speaker has about a moderate amount of magnet, and if it really has 9mm of xmax the generic specs from the site are realistic sounding, and you'd have a broadly useful sub driver to design with. Maybe the extremely low Q "version" would work OK in a horn, I have about zero experience with that, but it usually means you're going to get a -3dB point well above Fs for any other type of box, although it might be darned efficient.
My transmission line subs 4-21"Hide this!Advertise here!
how to combine Line array and transmission line together Jared Multi-Way 7 15th December 2012 01:20 PM
quad amped system rd-75 with 4 TL 21" subs ajhockett Planars & Exotics 7 7th April 2010 08:19 AM
3" Driver in a Transmission Line. chris661 Full Range 3 21st August 2009 09:43 AM
Transmission Line - "C m/s" 10K2HVN Multi-Way 4 31st March 2005 08:17 AM
8" Quartz pipe for Transmission Line speaker MRehorst Swap Meet 0 26th December 2002 11:00 PM
Copyright ©1999-2017 diyAudio
