Old 6th April 2010, 03:01 AM   #1
Default tapped horn gods
I am asking if anyone who know to design tapped horn very well can help me design one
I want to use 18 0r 21 inch speaker
I am open to any idea.
Old 6th April 2010, 04:25 AM   #2
soho54 is offline soho54  United States
See this thread Ricci's dual B&C 21SW152 build thread., and take one of the two TH's there as a starting point.
On the 600l version-I would drop the lower corner to ~20Hz, and shrink the mouth a little to keep it at the same size. You lose a few dB overall, but not enough to worry with. If you are willing to go over 650l you can gt the missing dBs back and more by raising S4.
Think S4 low 2k, L23 low 400s, and L34 80-90s.
For the 370l version just approximate the same percentage of change listed above.
If you drop the compression you can shrink S1 to normalize the frequency and impulse response back out.
Good luck.
Old 6th April 2010, 04:43 AM   #3
Thanks soho54
The Donald Tapped Horn Highef Subwoofers 29 12th March 2010 01:23 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Help with a tapped horn. mike james 533 Subwoofers 32 11th November 2009 02:34 AM
Page generated in 0.06422 seconds (68.78% PHP - 31.22% MySQL) with 10 queries
