Check this design out
Old 5th April 2010, 10:10 PM   #1
kornnylike is offline kornnylike  United States
Default Check this design out
Can anyone tell mi if this design is good or not
Old 6th April 2010, 12:32 PM   #2
David_Web is offline David_Web  Sweden
I don't like the solid bracing, had been known to decrease LF performance.
A few holes in chosen places should fix it though.
You should take the dimensions and input it into hornresp.
Or AkAbak of your up for it.
Way less expensive than building it to find out.
Old 6th April 2010, 04:59 PM   #3
MaVo is offline MaVo  Germany
I doubt that this is a problem. The solid bracing doenst do anything to the sound, except doubling the frequency of the standing waves in the horn, which is a good thing. If you have proof for your assertion, i would love to see it.
Old 7th April 2010, 12:54 PM   #4
It was mentioned in a post about the furybox due to actual testing. And I think Tom Danley also mentioned it in one of his posts.
You can also see that the DTS-20 has a gap in the bracing.
Old 7th April 2010, 04:31 PM   #5
Well, thats hard to check out for me... but after all, it shouldnt make much of a difference if you use solid bracing or not, except that its cheaper to use less bracing but in more important spots, like gedlee does in his closed box designs.
Old 7th April 2010, 08:42 PM   #6
FlipC is offline FlipC  United States
The Furybox is a Th and not a FLH.
A FLH will not be affected by a solid brace in mouth like a TH. The TH is effected due to the reverse wave path being altered. It has to be EXACTLY in phase with the forward wave at mouth exit.
And korny.
One day i am either going to build that SS modular you listed or the Rubic Horn.
Old 7th April 2010, 08:58 PM   #7
fzaad is offline fzaad  Europe
Question is what are you trying to accomplish in your design. Your design looks pretty much same than mine Fostek speakers witch were build in 80's. Those speaker had effiency around 120 db.
Check this design outHide this!Advertise here!
PSU Design Check Please ANDYLASER Power Supplies 14 15th July 2010 12:42 PM
New Here. Will you check me design? SightSeeker1 Subwoofers 19 13th April 2006 04:59 PM
My new design... double check please? Feandil Multi-Way 0 26th April 2005 04:46 AM
Please check my subwoofer design noodle_snacks Subwoofers 3 30th July 2004 06:19 PM
Copyright ©1999-2017 diyAudio
