#21 |
Hi Josh Ricci,
Here is your 400L TH from Post #18 w/ some modification, and basically the same volume. Frequency response and impulse response are slightly improved (it's about the same CON or EXP for the sections). Regards,
Oliver |
#22 |
TB46,
The only problem that I see with it is that the compression ratio is about 5.2/1. I have doubts about what a 21" cone, even a very sturdy one such as this can handle. My sim was at about 3/1 and some are of the opinion that it is already too much for such a large cone. BTW I have sent the 8ohm drivers back and will be getting a set of the 4ohm as they are what I originally intended to get. |
#23 |
Hi Josh Ricci,
I agree 5.2/1 would be quite high, but the compression ratio is Sd/S2 (not S1),or, about 2.6 to 1. There have been brief discussions of shortening the L12 distance, and decreasing S1 with screamerusa's furybox,and more recently in "jbell's set of four tapped horns". Regards,
Oliver |
| FS: 1 pair of B&C 21SW152-8 21" Subwoofer Drivers. | opc | Swap Meet | 14 | 6th February 2012 04:49 PM |
| Sachiko Build Thread! | woodturner-fran | Full Range | 115 | 9th February 2010 10:11 PM |
| Sorry another newbie build thread | soupdragon | Multi-Way | 30 | 9th December 2008 05:29 PM |
| New Project Build Thread | ryoung | Multi-Way | 5 | 19th April 2008 01:15 AM |
| The ESL Build Thread | BillH | Planars & Exotics | 172 | 8th November 2006 09:01 PM |
