Old 2nd April 2010, 08:38 PM   #1
subs is offline subs  United Kingdom
Default Isobaric HELP
hi there i have a pair of JBL 804 8" woofers i would like to put in a isobaric enclosure, Ive been told that a duel reflex bandpass would work in the space available L 14" H12.5" W10" maybe it would but i need to no air space for both chambers, port size & length if the enclosure isn't to small, if need be i could increase withe a bit more.
thanks subs
Old 2nd April 2010, 11:09 PM   #2
Hi. Do you have the TS parameters for this driver?
Old 3rd April 2010, 02:12 AM   #3
Hi odysseybmx414 yes i do have it. if you are talking about the THIELE-SMALL PARAMETERS. cant understand a word of it.
subs
Old 3rd April 2010, 07:01 AM   #4
chris661's Avatar
If you post them here, we can design some different cabs for you to choose from.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 4th April 2010, 02:03 AM   #5
Default Thiele-small parameters.
ok chris661 here it is
voice coil dc resistance: R evc (ohms) 3.49
voice coil inductance @ 1 khz l evc (mh) 1.64
driver radiating area: sd (in2) 33.17
sd(m2) 214.00
motor force factor: bl (tm) 12.88
compliance volume: v as (ft3) 0.58
v as (liters) 16.42
suspension compliance: c ms (um/N) 251.00
moving mass, air load: m ms (grams) 115.00
moving mass, diaphragm: m md (grams) 113.20
free-air resonance: fs (hz) 29.60
mechanical Q Qms 6.37
electrical Q Qes 0.450
total Q Qts 0.42
magnetic-gap height: hag (in) 3/8
hag (mm) 9.00
voice-coil height: h vc (in) 1-1/4
h vc (mm) 32
maximum excurtion: x max (in) 7/16
x max (mm) 11.50
SPECICATIONS
diameter: 8" (203mm)
sensitivity (2.83 v@ 1m): 91 db
power handling: 200 w rms 800 w peak
frequency response: 30~400 hz
nominal impedance: 4 ohms
voice-coil diameter: 2.0" (51.0 mm)
mounting depth 4-5/16" (110 mm)
i hope this helps you to configure me a isobaric box.
subs
isobaric keyser Subwoofers 9 9th December 2010 01:35 AM
isobaric damping.. ChesterFuzzin' Subwoofers 9 4th January 2006 12:30 AM
4x isobaric Jennice Subwoofers 42 17th May 2005 07:42 AM
using an isobaric ring? ChesterFuzzin' Multi-Way 1 16th April 2005 10:03 PM
Isobaric for subs only? speekergeek Multi-Way 8 13th January 2004 03:15 AM
Page generated in 0.09076 seconds (64.39% PHP - 35.61% MySQL) with 10 queries
