I'm fairly new to this DIY audio. I want to setup a empty room in my house
to be my listening area. It's 12.5X12ft, so not exactly big but it's empty. I'm thinking of getting 4 12" 8Ohm DVC's on a Crown XTI 1000. I believe it would run a 4ohm load on the XTI. I'm debating between a lower budget or going with the higher end. I listen to a wide variety of music, pop, rock, country. I think the cheaper woofers may be good enough. The XTI should be able to power them easily at low volumes with generous results. I'd welcome some advice on box design and overall any suggestions on woofers to buy. I have a some extra cash and I would love to get the XTI hooked up. It's been sitting around for nearly a year and bass is lacking on my home system. Thanks Parts-Express.com Parts-Express.com |
#2 |
I would use the DVC310. The extra oomph is worth the money IMO. I have some of the 15's. And if you ever get the bug to try out horns, the larger Dayton By Eminence DVCs lend themselves to that sort of thing.
I would also run the Xti at 8 ohms, not 4. Sure, it will *run*, but this model has a VERY FAST ACTING protection circuit which limits bass output at 2 or 4 ohms. If you were looking for amps, you would get advice steering you away from it - perhaps even toward the inexpensive EP4000. |
#3 |
Thanks for the info on the AMP. I might have to pick one up, I may just have to pick
one up. Wait and see what my account looks like after I pay bills. If that amp is stable to 2ohm, it should be able to push 8 of those puppies. That'd be awesome. Maybe do six, three in each box kind of like a "MartinLogan Descent." But a little bigger enclosure. Something to think about over the weekend. Use the XTI to push my main speakers. The AMC I have is good but they want more than the AMC pushes. |
#4 |
Hi nixtux,
I suggest you to build at least one T-TQWT: b |
| My Dayton Reference 12" Subwoofer | owdi | Subwoofers | 25 | 2nd June 2011 08:49 PM |
| Dayton RS 12" HIFI | basham | Subwoofers | 1 | 17th March 2006 05:32 PM |
| Dayton 12" HF sub box | AutoAudio | Subwoofers | 6 | 17th December 2005 02:46 PM |
| Peerless XXLS 12" DVC (830837)- replacement for PE Dayton 12" DVC 295-185? | tktran | Subwoofers | 2 | 14th August 2005 02:04 PM |
| Dayton 12" Dvc Vs Shiva Dvc 12" | crippledchicken | Subwoofers | 0 | 30th November 2004 01:20 AM |
| Page generated in 0.08367 seconds (78.24% PHP - 21.76% MySQL) with 11 queries |
