Old 1st April 2010, 03:51 PM   #1
Default need some help please
I need help to adjust these numbers in hornresp for this speaker
hornresp
s1=832
s2=1097
con=34
s3=1191
con=16,5
s4=1887,5
con=30,5
s5=3728,5
con=33,5
vrc=180
lrc=64
ap=390
lpt=25
atc=2418
vtc=27565
speaker
THIELE-SMALL PARAMETERS
Resonant Frequency (fs)
39.6HzImpedance (Re) 5.98 ohmsElectrical Factor(Qes).6Mechanical Q (Qms) 13.83Total Q (Qts) .57Compliance Equiv. Vol. (Vas) 154.14 Liters/5.44cu. ft.Voice Coil Overhang (Xmax)11.5mmBL Factor22.23 T-MDiaphragm Mass (Mms).199 kg.Surface Area of Cone (Sd)m20.1164m2Reference Efficiency1.54%Coil Inductance (Le)0.9mH
If the box is very large a problem
25hz to 90 hz at 130 db
Old 1st April 2010, 05:09 PM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by soundhead View Post
I need help to adjust these numbers in hornresp for this speaker..
..If the box is very large a problem..25hz to 90 hz at 130 db
Hi Soundhead,
Why do you want to morph a mid bass shoe dryer into a sub?
b
Old 1st April 2010, 06:27 PM   #3
bjorno this the design I want to put the speaker
It's a 3 meter long horn ... Click the image to open in full size.
112 dB 1/w/m 3ohz à 125 Hz à -6 dB
Old 1st April 2010, 07:05 PM   #4
So your HR 'con' numbers should be in inch and not in cm?
b
Old 1st April 2010, 07:31 PM   #5
i am a dummy to this thing
Old 1st April 2010, 07:35 PM   #6
bjorno can you help me
Old 2nd April 2010, 05:56 PM   #7
Hi soundhead,
First, I think you have to relax your peaked requirements concerning using the proposed driver.
The consequences when stating: ‘25hz to 90 hz at 130 db’ and then the proposed cabinet type here above resulted in: See the 11 m^3 horn shown in the submitted picture.
A more sensible design is simulated too, the TH, that due to the low expansion rate and throat compression = (1:1) should be stuffed like a T-TQWT in order to gain SQ.
Conclusion: Would the proposed driver be good substitute to the RCF-18N401 in posting #3? See the second picture here below.
b
Old 2nd April 2010, 06:52 PM   #8
Bjorno the name of the. Speaker I will be using is ciare 18 sw, also the TH design looks good. Can you draw up the design for me please or show me how to do it
Old 2nd April 2010, 07:10 PM   #9
Which design you like better
Page generated in 0.11967 seconds (77.01% PHP - 22.99% MySQL) with 10 queries
