The DubHorn:Wi's TC 5100NEO loaded 20hz horn. - Page 5 - diyAudio
Old 1st April 2010, 06:03 AM   #41
FlipC is offline FlipC  United States
Checking out the C&S remix as I type.
Someone post the correct HR inputs for that TC 18 sub.
TC Sounds Pro 5100 18 1K rms 4K peak 19.1 X 38.1Xmech 94.5db 2x2 ohm
So 19.1 is Xmax and 38.1 is Xlim - not Xmax ?
I used a general SD of 1680 and went from there. Put it into my TH 221 clone sim and get 137 DB at 20 Hz 2 Pi 133 v ! Though 24-28 Hz cause some issues. You could just build a single one of these and have it vertical with permanent caster like the Th 812 from Danley.
I think that would dismantle a house!
150 Db at .5 pi @ 20 Hz. Bajeebus ! Would make me nut my pants at full tilt.
And tx klank for the posting about that remix.
I do like the rap over it. Will use it to flip the script on the original.
Old 1st April 2010, 06:10 AM   #42
Pro-5100 NEO
Qts 0.245 Total Q
Qes 0.25 Electrical Q
Qms 6.9 Mechanical Q
Fs 26.5 Hertz, Free Air Resonance
Res 3.02 Ohms, DC resistance
Ls 2.8 H, series inductance
Lp 4.2 H, lossy series inductance
Rp 5.3 Ohms, loss across Lp
Dia 390 m meters, effective
Vas 251 liters, air volume equivalent
mms 287 grams, effective mass
cms 125 um/N, compliance
bl 23.8 T*m, motor strength
SplSens 94.5 dBSPL max @1W absorbed
Geometric Stroke 19.1 Millimeters, (voice coil - gap) / 2
70% BL 31.0 Millimeters, BL is 0.7 original value (one way)
Xmech 38.1 Mechanical displacement limit (one way)
Long Term Power 1000 Watts
Program Power 4000 Watts, short term peak power limit
Sd 0.1195 sq m
Old 1st April 2010, 07:01 AM   #43
Just wanted to drop in that my fav dupstep track lately is Bassnectar's cover of Nelly Futado's Beautiful World.
Old 2nd April 2010, 01:41 PM   #44
Quick update:
After looking at ported, front loaded horn, and tapped horn, the tapped horn is looking the best for efficiency and output. The first graph is 1vs2, the second graph is 2vs4 half space, and the third graph is the excursion plot at 976w.
More info forthcoming.
Old 2nd April 2010, 02:41 PM   #45
BP1Fanatic's Avatar
Post your Hornresp inputs!
Old 2nd April 2010, 02:43 PM   #46
Maybe
Old 3rd April 2010, 03:59 AM   #47
BP1Fanatic's Avatar
Am I close?
Old 3rd April 2010, 07:33 AM   #48
Compression ratio is way too high for an 18" driver, but other than that, you're getting there...
Not speaking for Wi directly, but knowing the others involved with this, I'm pretty sure things will be shared once the course is decided.
Old 3rd April 2010, 06:32 PM   #49
+1
Old 4th April 2010, 07:52 PM   #50
BP1Fanatic's Avatar
How about this?
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 08:32 PM
Volvotreter 20Hz Tapped Horn build (pics) RadiantNRG Subwoofers 77 27th July 2015 05:18 AM
Which Horn for linear response down to 20Hz? Bass-Depth Subwoofers 81 2nd September 2005 02:59 AM
Copyright 1999-2017 diyAudio
