The DubHorn:Wi's TC 5100NEO loaded 20hz horn.
Old 8th March 2012, 12:03 PM   #171
Dirk95100 is offline Dirk95100
Originally Posted by salzburgsoundsystem View Post
Assuming this amplifier is outputting no more than 45 Watts into each driver, moving up to 200 Watts should add 6 dB.
Connecting a second pair of these cabinets on a second 2 x 200 Watt amp should give us another 3 dB.
126 + 9 = 135?
and that is just from 4.
and then I'll put them on the floor, in a corner.
This is going to be fun!
Regards, Ben
Very interesting stuff!
But I'm a bit confused, how low go these and what size are they?
Old 8th March 2012, 04:07 PM   #172
m R g S r is offline m R g S r  United States
Click the image to open in full size.[/QUOTE]
That's not 1m testing...What voltage was Applied to the drivers to get that?
Old 9th March 2012, 06:12 AM   #173
salzburgsoundsystem is offline salzburgsoundsystem  Austria
Default m R g S r is correct
That's not 1m testing...What voltage was Applied to the drivers to get that?[/QUOTE]
That's right. Testing was not at 1m, nor at a specific voltage. No such claims were made.
When I do proper outdoor testing with sine waves at measured voltages at 1 and 10m I will be happy to share the results. As said above, this was no more than playing the mono summed bass from music (using the iPod) through a basic dj mixer and 45W rms amplifier. This was in a relatively small room and too close to walls, the ceiling and floor to be considered a room suitable for measurements.
If you want serious data, this is not it. I only wanted to have a little proof of concept, to see that my work had not been wasted so far. When the snow has melted and the ground below it is no longer frozen solid I shall do further proper testing.
Regards, Ben
Old 23rd August 2012, 08:38 PM   #174
Not sure if it's been posted but the 5100's are on special from parts express right now for $880.
I still wouldn't buy at that price but just a heads up!
Old 23rd August 2012, 08:44 PM   #175
Wisounds is offline Wisounds  United States
Talk about back from the dead. This project was scrapped when TC revised the pricing on the 5100 and it became 1500$. Even at the 880$ "special price", no driver is worth that. I think they were 550$ originally at the start of this one.
I built 4 18" loaded 23hz vented cabs with FaitalPRO drives and they kick serious tail. So do my new line arrays at +/-1db from 300-12k with 2 bands of EQ.
Old 23rd August 2012, 09:32 PM   #176
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Boooooo...what happened to building horns?
Old 24th August 2012, 02:21 AM   #177
Honestly, I like the visceral quality of the vented cabinets. Standing in front of the 4 new 18s and a pair of 21s is a truly engaging experience. When the concrete floor under the rig modulates, I'm doing something right. My FR, waterfalls, and impulse response turned out exceptional. I still need to encounter the right conditions for THD measurements. The vented Faital cabs are the first I am happy with and would put my name on for resale. I'm going to build 4 more, they are simply nasty. The kickbins are going to get a redesign next. The subs and tops are settled. I do need to execute a few small baffle revisions on the tops.
I am the closest I have ever been to the system I have been envisioning for almost a decade.
Old 24th August 2012, 09:23 AM   #178
Default Interesting - full circle then, but with much better drivers...
Wisounds,
thanks for inspiring the project that I adopted! Can we take a look at your new system? What are your frequency response -3dB and max spl specifications and drivers?
Regards, Ben
Old 24th August 2012, 05:32 PM   #179
I just reviewed the thread, I'm glad you were able to get a cabinet out of it that suits your needs!
WiRay210 prototype build, +/-1db from 300-12k with measurements:
WiRay 210 prototype build thread, Faital 10s and planar HF horns
4 FaitalPRO 18HP1060 build:
4x FaitalPRO 18HP1060 build thread.
Latest measurements of a few drivers in a few different cabs:
Measuring party part Deux, 4 drivers(3-18s, 1-21) 2 enclosures.
Old 26th August 2012, 12:55 AM   #180
BP1Fanatic's Avatar
I just responded on avs about the br's. THAT is the way to build one!
The DubHorn:Wi's TC 5100NEO loaded 20hz horn.Hide this!Advertise here!
Volvotreter 20Hz Tapped Horn build (pics) RadiantNRG Subwoofers 83 23rd July 2017 11:06 PM
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 09:32 PM
Which Horn for linear response down to 20Hz? Bass-Depth Subwoofers 81 2nd September 2005 03:59 AM
