The DubHorn:Wi's TC 5100NEO loaded 20hz horn.
Old 29th November 2011, 01:45 PM   #121
salzburgsoundsystem is offline salzburgsoundsystem  Austria
Default Sounds good!
I do have a bunch of high and medium density acoustic foam for treating rooms.
To maximise clearance between the wood and vent, the space directly behind the vent could be left free I could cut a circle out of a block of foam, leaving a ring of foam around the vent?
Sorry I keep bringing up the kappa 15s, I've been regretting their purchase for so long! They seem to be neither fish nor fowl, being optimal for neither tops due to their weight and size - I prefer 10" and 12" mid basses - nor for subs due to xmax etc...
I can't find anyone who wants to buy them and hate to throw drivers away or have them gather dust...
Regards, Ben
Old 29th November 2011, 02:27 PM   #122
tb46 is offline tb46  United States
Hi salsburgsoundsystem,
When you plug the Eminence Kappa 15A into Hornresp, it looks like it wants to be a mid-bass FLH, about 85-400Hz. Think of a design similar to the Klipsch LaScala bass section.
Oliver
Old 29th November 2011, 02:37 PM   #123
Default Thanks Oliver!
sounds like it would nicely complement the Dubhorns I am building for sub bass!
How big and complex a box are we talking, straight horns or exponential?
Regards, Ben
Old 29th November 2011, 02:51 PM   #124
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Originally Posted by Wisounds View Post
I had actually ended up deciding on using the Epic 10". Simulations showed that using 6 smaller horns at 500w each hit 140 at 20hz.
The 5100Neo ended up in a refrigerator sized enclosure, and stacking reflex boxes proved the better option as it had to be mobile. The LMS-R12 faced the same issue.
6 smaller boxes that soak up more power and are easier to move than a large one seemed the way to go.
Then I ran out of money to continue pursuing the project, so it is on the back burner right now.
Has this project moved to the front burner yet?
Old 29th November 2011, 02:57 PM   #125
Default It's on my front burner!
Jbell is making sure the mix of ingredients is just right!
Old 29th November 2011, 03:19 PM   #126
Default Posts #122/123:
Hi Ben,
Look for plans of the Klipsch LaScala. The bass unit is roughly 2'x2'x2' (61cm cube).
Oliver
Old 29th November 2011, 03:57 PM   #127
jbell is offline jbell  United States
I think oliver has the right idea. kappa 15a's work best as kick bin above subs, and below tops in a 4way.
It's either that or put them under some nasty compression driver that makes ears bleed and make 15+1's and sell them off to the low end dj crowd...
Old 29th November 2011, 04:12 PM   #128
Hi jbell,
Sounds like a plan :-).
Oliver
Old 29th November 2011, 04:52 PM   #129
Default Actually...
Once a month, I am a low end dj
Old 29th November 2011, 05:25 PM   #130
you are far from that my friend....
The DubHorn:Wi's TC 5100NEO loaded 20hz horn.Hide this!Advertise here!
Volvotreter 20Hz Tapped Horn build (pics) RadiantNRG Subwoofers 83 23rd July 2017 10:06 PM
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 08:32 PM
Which Horn for linear response down to 20Hz? Bass-Depth Subwoofers 81 2nd September 2005 02:59 AM
