High efficiency low frequency speaker system
by Arnold I. Klayman Patent number: 5177329 Filing date: May 29, 1991 Issue date: Jan 5, 1993 Note in particular his description of figure two in the application. BTW, hello to the group. I am a 53 year old relative newbie to speaker design, hindered by a distaste for math and no brain for any type of equations. However, I do have a deep interest in speaker design, and I can be fairly imaginative towards subjects that interest me. I have a few ideas... However, I understand the necessity of learning Hornresp. It's eating my lunch! Maybe now though, being a member and able to download the driver specs used in the tutorial will make a difference when I get up enough ambition to try it again. In the meantime, I stumbled upon the following pdf while researching DIY speaker design, and I am inspired by the possible application of using the within info to design an enclosure that could serve as an experimental tool for tapped horns/TPQW by having reconfigurable flare configurations and interchangeable panels for different drivers, etc. |
#2 |
Candidates for the Darwin Award should not read this author. |
#3 |
You can go much further back to see the origin of this loading idea. It seems to be "re invented" every 10 years. Robert PRUDEN - 1956 Iain. |
#4 | |||
True. I only brought this up because my memory failed me regarding this post by Danly here at DIYAudio: Evolution of the Tapped Horn -in particular the following quote: Quote:
I stand corrected. Later, Dane |
#5 | |
So, how many years 'till I can patent an acoustic suspension speaker?
| The Donald Tapped Horn | Highef | Subwoofers | 29 | 12th March 2010 01:23 PM |
| Can a Tapped Horn have a negative taper within the horn path? | BP1Fanatic | Subwoofers | 6 | 13th February 2010 06:04 AM |
| Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background | layertone | Subwoofers | 15 | 23rd January 2010 05:12 AM |
| Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background | layertone | Full Range | 2 | 23rd December 2009 12:51 AM |
| Help with a tapped horn. | mike james 533 | Subwoofers | 32 | 11th November 2009 02:34 AM |
| Page generated in 0.09054 seconds (70.99% PHP - 29.01% MySQL) with 10 queries |
