Possibly, the greatest non-servo subwoofer amp ever!
Old 17th March 2010, 09:51 PM   #1
jeffca is offline jeffca  United States
Default Possibly, the greatest non-servo subwoofer amp ever!
I've been designing a new bass guitar rig. One version is a ~1cu.ft. sub cabinet with four, 10" Dayton Titanic subs in a bipole configuration for below 200hz. Above that are two 24" tall cabinets stacked to create a line array. Those will be loaded with four, Dayton RS125T-8, 5" mid-woofers and 6 BG Neo-3 PDR tweeters bringing the final total to 4 sub drivers, 8 mid-woofers and 12 tweeters. Hell, with two of these, you could have a really potent hi-fi PA system for a small venue.
In the process of researching how I'd power this portable beast, I considered amps from several manufacturers and came upon the Crown XTi 1000. While the ratings are pushed close to clipping (275W, 0.5% THD, Stereo, 8 ohms per ch.), the amp will drive a 2 ohm load (700W). Add to that a full DSP section with 8 bands of EQ, a fully configurable crossover network, limiter, alignment delay and a pink noise generator.
Sounds good (maybe too good)? Add to that, free software to configure the DSP section via USB and a 3-year, no fault warranty. If you blow the amp up, they replace it, period. Now that sounds pretty fantastic. And, because it's a Class I amp, it's about 85% efficient and only pulls 38 watts at idle.
The price, you ask? Musician's Friend sells B-Stock units for $400, most other places sell new for $500. For an extra $300, you can almost triple your power with the XTi 4000.
Check it out at XTi Series. I'm not a rep for the company. I just think that this is a huge bargain that people should know about. Why power you subs with a cheap plate amp when you can have a real amp?
Do forget to scroll through the photos so you can check out DSP software... quite sweet.
jeff
Old 19th March 2010, 02:23 AM   #2
zora is offline zora  United States
Before you get too excited, head over to AVS and look at the amp test thread. To say that the XTI series disappointed a few folks (real world power output) would be an understatement.
Old 19th March 2010, 07:10 AM   #3
poynton is offline poynton  United Kingdom
poynton's Avatar
I think the best asset for this amp is the 3-year, no-quibble warranty.
Very useful for a portable system !
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 20th March 2010, 02:40 AM   #4
davygrvy is offline davygrvy  United States
davygrvy's Avatar
AVS Forum - View Single Post - Measuring Amplifiers
Think out of the box
Old 20th March 2010, 03:09 PM   #5
Interesting. Seems that there is a high pass filter somewhere in the system. Wonder if the DSP section was off for this test? Doing some research, I'd run into several less than glowing reviews of the XTi series in it's first few years out (2005 - 2007), but that's changed in the last year or so. Seems that they over-reached and took them a while to sort out their issues.
I'm going to be in touch with Crown about this. Response to 10hz should be near perfect. I'll post back about what I found.
Possibly, the greatest non-servo subwoofer amp ever!Hide this!Advertise here!
Subwoofer Servo Chris Rudden Subwoofers 16 30th July 2012 03:38 AM
Spica Servo Subwoofer willworkforfood Subwoofers 0 29th January 2008 04:21 AM
Servo-feedback Subwoofer dswiston Digital Source 25 26th October 2005 05:07 AM
Servo rotary subwoofer! Audiophilenoob Subwoofers 17 6th October 2005 12:37 AM
Copyright ©1999-2017 diyAudio
