here are the sub parameters for 2 10" ers
Lem mh 3.185 REve 3.83 sd. sq m .0379 bl tm 13.89 vas 34.36 mms gram 116.53 fs 35.7 qms 10.012 qes .523 qts .497 xmax 9.2 tuning of about 40hz would be awesome if you can shoot me box dimensions and also the hornresp sheet I am still learning so if I can copy your #'s and duplicate the same charts I will start to feel more confident in my abilities.. Thanks a ton for the help!!!! |
#2 |
What size room, type of listening, what are the mains you will be using and what sound do you like?
#3 |
how big?
and how's the boat project coming... |
#4 |
[QUOTE=justint;2120283]
tuning of about 40hz would be awesome QUOTE] Hi justint, Here is a HR suggestion tuned at 30 Hz with in band phase (gldy), IMO a TH suitable for to be used in a home environment: b |
#5 |
jbell.. boat project is coming along.. I just got back from spring break in cancun so it got delayed I would say end of next week the 8 8's will be ready for action.. Very excited to see this..
#6 |
room size is 25x25 with 20 foot ceilings in my house open concept home so technicallyy the space is probobly substantially larger.. Mains are running 2 jbl eon 15's
#7 |
Hi justint,
Are the parameters in Post #1 measured, and can you provide the name of the drivers? As a first guess I would say that a tapped horn similar to the TH-SPUD might work. Regards,
Oliver |
#8 |
#9 |
Thanks jbell.
Oliver |
#10 |
these are the kickers same size but different model.. lucky me I picked up 2 brand new ones that for $20 from my buddy who wasn't using them... The parameters are pulled directly from the website. they are the CVT model 10" 4 ohm
| need loud and low.. size doesn't matter | justint | Subwoofers | 14 | 24th February 2010 09:00 PM |
| Please help! How is this SOOO loud and low? | Bias the Gate | Subwoofers | 80 | 19th December 2009 10:10 PM |
| Newbie design goals: how low/loud? | NogginBoink | Subwoofers | 32 | 3rd August 2005 11:10 AM |
| Page generated in 0.08859 seconds (79.87% PHP - 20.13% MySQL) with 11 queries |
