Old 15th March 2010, 08:38 AM   #1
Default 2x Peerless SLS 315 Sub
I`m planing too build a sub woofer using my two Peerless SLS 315.
http://www.madisound.com/catalog/PDF...ess/830669.pdf
Just want to know what you think considering box size and tuning.
(three different tunings because I´m planing too use 3 BR pipes)
I´m hoping that with room gain and 3-6dB EQ this will play within at least -10dB @ 20Hz.
Another alternative would be Acoustic Valve(if someone can explain how it works)
Old 16th March 2010, 12:43 AM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
[QUOTE=urkain87;2119515]I`m planing too build a sub woofer using my two Peerless SLS 315..
..Just want to know what you think considering box size and tuning..
QUOTE]
Hi ukraina87,
Looks ok,, for more hints see the zipped picture:
b
Old 16th March 2010, 05:03 AM   #3
I have too say, I´m impressed with the effort you have out intoo helping me
If i understand this right the image is a TL design with quarter wave tuning at about 35Hz(28Hz with stuffing and narrowing line)?
But the enclosure becomes really big with this design...
Compareing graphs from a simple BR with the same volume for one driver I would get about the same result. Although i wil take this into serious consideration
Can i reduse the total volume of the box while still maintaning the length of the line with an isobarrik configuration?
Old 16th March 2010, 11:45 AM   #4
Originally Posted by urkain87 View Post
..I have too say, I´m impressed with the effort you have out intoo helping me
If i understand this right the image is a TL design with quarter wave tuning at about 35Hz(28Hz with stuffing and narrowing line)?..
Thank you for the nice words but IME the tools I use is very easy to use, then it's only a cut and paste process lasting a couple of minutes.
Yes, it's a Tapped Tapered Quarter wave Tube or a Tapped TL as you wish.
..But the enclosure becomes really big with this design...
Compareing graphs from a simple BR with the same volume for one driver I would get about the same result. Although i wil take this into serious consideration..
The only difference is that the T-TQWT widens the BW by almost an octave lower.
..Can i reduse the total volume of the box while still maintaning the length of the line with an isobarrik configuration?..
You are right, just cut the CSA: s in half for an isobaric T-TQWT while maintaining the length as before. See the picture:
b
File Type: gif Isobaric_Peerless830669_T-TQWT_portedbox.GIF (144.6 KB, 439 views)
Old 16th March 2010, 08:53 PM   #5
Hmm... Looks like this might turn into a more interesting project than i expected
Now the question becomes: should i go for the TL, or a small(50L) isobarik closed box... I have done some simulations and with a closed box they will play in phase with my xxls sub.
hmmmmmmm....
Anyways, i need too buy some MDF now
Old 16th March 2010, 08:59 PM   #6
btw, what program are you using?
Old 18th March 2010, 04:58 AM   #7
I think this will be my final design: Reason being the box size and better flexibility than TL. Also a lack of experience with TL on my part makes the chances of success with BR way higher
Red: Closed box
Green: One BR port open
Blue: Both BR ports open
Yellow: just for reference, as i already have a xxls sub.
All in 82L boxes with isobarik configuration.
As you can see the closed system plays very well in phase with the xxls, so does the Green BR. The Blue BR i think will sound good in for party use
Questions:
Looks like i will loose 6dB SPL with isobarik, but how much max SPL will i loose?
Does isobarik reduce cone excursion due too the higher preassure levels?
Old 18th March 2010, 01:35 PM   #8
[QUOTE=urkain87;2123133]..Reason being the box size and better flexibility than TL..[QUOTE]
Hi urcain87,
The impact of the box size is a defendable reason but the flexibility (and SQ performance) IMO: No way! See the first picture here below.
[QUOTE=urkain87;2123133]..The Blue BR i think will sound good in for party use ..[QUOTE]
Once the Qts for a driver is at or over 0.5, it’s not really suited for a BR box (the SQ will be low) unless making the Speaker system Aperiodic or applying Qm damping, LT or by using a negative resistance amplifier. Se the second picture.
b
Old 20th August 2011, 09:12 AM   #9
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Hi Urkain87, did you ever build this sub, how does it sound?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 20th August 2011, 04:05 PM   #10
Hi, i found another use for the SLS´s, an open baffle configuration.
They sound very clean(low distortion) even at high excursion, and they have a very SMOOTH frequency response all the way up too about 1khz.
I did use one as a woofer in my car for a while. sounded great, but needs a big 50L+ box. Mabe even 80L per driver.
Here is a link:
Fast, fun, Inexpensive OB project
2x Peerless SLS-10 Transmission Line Sub michaelpage26 Subwoofers 12 26th April 2006 12:18 PM
Peerless SLS 400 4real Multi-Way 12 26th October 2005 05:37 PM
Peerless SWR-315 Xsus, X(spider/mag)? LS Multi-Way 0 7th July 2004 03:29 AM
Peerless SLS Mats J Multi-Way 9 3rd April 2004 11:10 PM
Peerless SLS 315 /Sealed Sub LageB Multi-Way 0 24th February 2003 09:51 AM
Page generated in 0.12441 seconds (74.05% PHP - 25.95% MySQL) with 11 queries
