![]() are these Pryamid Woofers any Good?...anybody used them? also...they are listed under the Home Speakers Section but they seem more like Car Audio Woofers. ![]() the Goldwoods look intreasting and Better Built than the Pryamid's. does anyone Reccomend either of these?...is either one better Sound and Quality Wise?...or should i look elsewhere? Intended use would be the Bass for a 3 Way Speaker.... |
#2 |
I'm pretty happy with the Goldwoods. I used the 6.5's in my car. Not bad at all for the price. My friend had really good luck with the Goldwood 8's for home use.
#3 |
What kind of a budget do you have?
Jim J. |
#4 |
Depends on your end use of the speakers. The T/S parameters may work better with one speaker over the other depending on your box design.
I used a pair of Pyramid speakers in some ported boxes and the the parameters happened to work well. In my case, the speakers were actually produced by Eminence as I found when I dug up the PDF. |
#5 | |
| WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) | gtforme00 | Swap Meet | 9 | 3rd June 2008 09:57 PM |
| anyone has experience with goldwood 10" woofers ? | angeloitacare | Multi-Way | 0 | 6th January 2008 05:28 PM |
| 8" 4 ohm heavy duty woofer/midbass needed, who's Goldwood? | eRiCdWoNg | Multi-Way | 11 | 29th February 2004 06:11 PM |
| FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers | cm7 | Swap Meet | 0 | 1st August 2003 01:59 PM |
| Need some good 8" woofers!~ | Duo | Multi-Way | 3 | 7th January 2003 05:48 AM |
| Page generated in 0.07158 seconds (77.33% PHP - 22.67% MySQL) with 10 queries |
