I'm building a pair of subs - left & right channels - 10" drivers.
Internal dimensions H 664 x D 414 x W 264mm. This is approximately 1 : 1.66 : 2.66 ratio. Crossover about 100Hz. Cabinets positioned 1 meter from wall with other drivers in separate cabs on top. I'm wondering what is the ideal position for the drivers within the cabinets. I'm sure there's an ideal ratio but not sure what it is. Can someone help me please |
#2 |
Every mode will be above the passband for a box of those dimensions, so it won't matter where you put the driver.
#3 |
frugal-phile(tm)
What Brett says is true wrt to the box itself, but placment wrt boundaries can have a significant effect.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Thanks for your feedback,
Does that means that I also do not have to worry about the 1 : 1.66 : 2.66 dimension ratio ? That would be great because aesthetically I would prefer something else. Last edited by mikelm; 28th February 2010 at 02:12 PM. |
#5 |
You won't need to worry about the dimension ratios with an upper limit of 100Hz and a maximal dimension of 664mm.
Not sure I fully understand what Planet10 is saying, but I think he means that placing the driver nearer to the enclosure walls may lend boundary reinforcement to some extent? Either that or positionining the driver with the box placement in relation to surrounding walls in mind to take advantage of room reinforcement. |
#6 |
...truth seeker...
wrt ROOM boundaries, placement in the room
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#7 |
frugal-phile(tm)
| bib driver position | skite30 | Full Range | 8 | 1st September 2008 06:35 AM |
| 25-position switched attenuator using a pair of 5-position switches? | ray_moth | Tubes / Valves | 1 | 4th May 2008 08:02 AM |
| Driver Position | hlj | Full Range | 2 | 1st June 2006 06:26 PM |
| Which driver/cabinet should I go for? | phresh | Full Range | 0 | 25th May 2006 09:12 PM |
| Bass impact with driver position | drfrink24 | Subwoofers | 18 | 26th January 2005 10:02 PM |
| Page generated in 0.08569 seconds (78.96% PHP - 21.04% MySQL) with 10 queries |
