What do you think about this sub?
Reckhorn.com
RECKHORN H-80
concept front loaded coner horn with cylinder enclousure and bottom side sound output design cylinder covered with black microfibre textile and top side natural marble plate
driver 13" woofer W-330D4 with dual voice coil
impedance variable 2 x 4 ohms or 1 x 8 ohms or 1 x 2 ohms
efficiency 95 dB 1 watt / 1 meter in 50 m² living rooms
frequency range 20 - 500 Hz
recommended range 20 - 80 Hz
power handling 2 x 100 watts rms
impulse power 2 x 200 watts / 2 seconds
dimensions height 75 cm + foot 8 cm, diameter 39 cm
weight 16 kg
recommended cable 4 mm² up to 10 meters, 6 mm² up to 20 meters
Its cost is just 159 euro
H-80 Eckhorn - profi hifi Vertriebsgesellschaft m.b.H.
Reckhorn.com
RECKHORN H-80
weight 16 kg
