H-80 Eckhorn
H-80 Eckhorn
Old 27th February 2010, 07:09 PM   #1
piero7 is offline piero7  Italy
piero7's Avatar
Default H-80 Eckhorn
What do you think about this sub?
Reckhorn.com
RECKHORN H-80
concept front loaded coner horn with cylinder enclousure and bottom side sound output design cylinder covered with black microfibre textile and top side natural marble plate
driver 13" woofer W-330D4 with dual voice coil
impedance variable 2 x 4 ohms or 1 x 8 ohms or 1 x 2 ohms
efficiency 95 dB 1 watt / 1 meter in 50 m living rooms
frequency range 20 - 500 Hz
recommended range 20 - 80 Hz
power handling 2 x 100 watts rms
impulse power 2 x 200 watts / 2 seconds
dimensions height 75 cm + foot 8 cm, diameter 39 cm
weight 16 kg
recommended cable 4 mm up to 10 meters, 6 mm up to 20 meters
Its cost is just 159 euro
H-80 Eckhorn - profi hifi Vertriebsgesellschaft m.b.H.
Old 28th February 2010, 12:00 AM   #2
MaVo is offline MaVo  Germany
Undersized, no measurements, non-standart shape. I would ignore it.
H-80 EckhornHide this!Advertise here!
Marantz SC-80 / SM-80 repair queries Low Orbit Solid State 2 26th May 2010 06:36 PM
EckHorn Nicola Multi-Way 14 9th August 2007 09:12 PM
any-one want a CD-80? honsten Digital Source 1 23rd June 2007 02:16 PM
Yamaha M-80 Tejaus Solid State 2 11th February 2006 03:24 AM
