folded horn subwoofer for single 10" driver
Old 9th March 2010, 06:38 AM   #11
davygrvy is offline davygrvy  United States
davygrvy's Avatar
I run Ubuntu 9.10 and use hornresp inside VirtualBox running XP. I didn't have good luck running it under Wine. Wine runs LTspice just fine though.
Think out of the box
Old 9th March 2010, 12:27 PM   #12
jbell is offline jbell  United States
Originally Posted by djdaveysprocket View Post
I'm still a little confused, I've successfully acquired WINE and HORNRESP but I don't understand it one bit.
Also not sure about the 8 foot bit. Is the box 8 feet tall (16 feet of horn), or is it an 8 foot horn folded in half to make a 4 foot box
yep, 8' tall. You said you had 6' to 8' of height. As simmed, it's roughly 12x12x96. That would make a nice slender column in the corner.
If this is too tall, you can double fold it, and roughly double the depth from 12" to 24", and make it about 4' tall.
Old 9th March 2010, 11:34 PM   #13
djdaveysprocket is offline djdaveysprocket  United States
Thank you littlemike, it's going to take me a quite a bit of studying to get the hang of hornresp, but the link you gave helps alot. I'm not much of a math whiz so it will be a challenge.
thank you guys, David.
Old 10th March 2010, 02:02 AM   #14
mashaffer is offline mashaffer  United States
Littlemike, I have taken to using an XP machine for hornresp as when running under Wine in Ubuntu always crashes when I try to use the Segment wizard or TH wizard. Did you ever have that trouble?
The only reason I drive the 91 Colony Park is that I can't afford a 65. Me old school? Couldn't be.
Old 10th March 2010, 04:25 AM   #15
littlemike is offline littlemike  United States
Honestly, 99.99% of my hornresp efforts are on Windows box. I set it up under WINE to see if I could, as I dual-boot Ubuntu and XP on my Laptop.
Sorry I can't be of more help.
Old 11th March 2010, 03:31 AM   #16
davygrvy's Avatar
VirtualBox, do it. There's a pre-built for Ubuntu already in the software center.
Old 12th March 2010, 08:57 PM   #17
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
So VirtualBox, Ubuntu, & WINE are to help non-Windows OS' use Hornresp?
Old 12th March 2010, 10:44 PM   #18
Specifically Linux users, though OSX also makes this list with a little effort.
Old 4th April 2010, 06:03 AM   #19
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Okay it's built, and it sounds amazing, I've never heard so much from a single 10" sub.
Thank you all for the help!!!
I enclosed pics of the process
I do have one issue though, it seems to be distorting or canceling out at the low end, and I'm wondering if there was some sort of adjustment I could make to remedy the problem, while I was building it I started worrying if I should have taken the area of the back side of the driver into consideration because it is right in the mouth and is quite massiveClick the image to open in full size.
Old 4th April 2010, 06:06 AM   #20
Next project, frugalhorns already started
folded horn subwoofer for single 10" driverHide this!Advertise here!
Driver inside of mouth of a folded conical horn ultrakaz Full Range 17 19th May 2009 05:56 AM
10" driver for Bass tower in Horn project angeloitacare Multi-Way 22 29th November 2007 01:10 PM
Can I multiply an 18" folded horn cab by 0.8 for a 15"? Optical Subwoofers 7 31st October 2004 04:37 AM
Suggestions for small (8"/10") subwoofer driver? netgeek Subwoofers 17 22nd December 2003 06:01 PM
